Tubes from BD 808 to BD 808s?
woofer
Posted: Wed Feb 25, 2009 3:06 pm    Post subject: Tubes from BD 808 to BD 808s?
Is the tubs from a 808 compatible whit the 808s? I have a damagd 808 but whit whery good tubes and a 808s thats in very good condition acept it has very bad tubes. Can i pull out all the conectorn and change the complet tubearray from the 808 whit neckbord and all focusrings etc still atacht and just install the hole array in the 808s? That wolud be a lot less work if so. It looks like evryting is the same but the partnumbers does not match.
If so anyting in particular that i shuld think about?
Posted: Wed Feb 25, 2009 3:13 pm    Post subject:
Yes, the BD808, BD808s and Bg808 all use the same tubes (Panasonic).
the BG808s uses Sony tubes, and without mods, can't be swapped between the other sets.
