Marquee Set Up Question
Ohmess
Posted: Mon Feb 23, 2009 12:23 am    Post subject: Marquee Set Up Question
I have one of the new Moome HDMI 1.3 cards and have a setup question.
I have all my sources connected to a Lumagen HDP and the HDP is connected via both RGBHV to the VIM and HDI/HDMI cables to the VIM through the Moome card on my Marquee. When connected this way, my Marquee only sees the input through the Moome card. If I pull the HDI/HDMI cable, I get nothing. If I pull the Moome card, the analog input appears.
It appears that the Moome card takes over the VIM when it is connected.
Is there a way to tell the Marquee to ignore the Moome card input? I would like to be able to maintain the analog connections.
Posted: Mon Feb 23, 2009 12:44 am    Post subject:
Source 1
Posted: Mon Feb 23, 2009 1:20 am    Post subject:
you need to create channels in the Utilities menu. Input 1 is RGB and input 2 is Moome. Also a separate channel for each resolution. You switch between them by choosing 1 eneter, 2 enter, etc. You can also add the channels to up/down list and switch with arrow keys.
