Help with NEC XG 75
fishmann2
Posted: Sat Feb 14, 2009 11:24 pm    Post subject: Help with NEC XG 75
I've been trying to set up my XG75, but haven't had much luck. It only works on the rgbhv input, and sometimes on the s-video. If I turn in on with no input it flashes on and off unregistered input. What's wrong?
Posted: Sat Feb 14, 2009 11:28 pm    Post subject: Re: Help with NEC XG 75
The flashing on and off and unregistered signal is normal with no input. So what would be your problem then? Smile
Let me rephrase that, it sounds sarcastic........your projector needs a signal to stabilize. Whats up with the S video? Elaborate....
fishmann2
Posted: Sat Feb 14, 2009 11:48 pm    Post subject:
Sometimes it will flsh on and off even with the svideo input. Also, I'm unable to start the projector up on anything other than the rgbhv input.
Posted: Sun Feb 15, 2009 12:16 am    Post subject:
Just curious but why do you want to run S video to this projector? It is the worst signal you could use. You loose all the advantages of a higher resolution.
fishmann2
Posted: Tue Feb 17, 2009 10:54 pm    Post subject:
It's the input that my receiver uses for its menu. If I need ti change any settings on my receiver I have to use the s-video. Also, how do I get the projector to save settings. Everytime I hit store it says cannot store or something similar.
wallace123456
Posted: Tue Feb 17, 2009 11:10 pm    Post subject:
You need to get some input registrations set.
See these links:
http://www.curtpalme.com/NECPG_MechSetup4.shtm
http://www.curtpalme.com/NECXG_Downloads.shtm
wallace
Bruce 09
Posted: Tue Feb 17, 2009 11:20 pm    Post subject:
This guide will help once you get a decent source.
http://www.curtpalme.com/CRTSetupGuide.shtm
Bruce
