Brian C
| Posted: Sat Feb 14, 2009 7:32 am Post subject: Zenith Pro1200x.... 230v? |
Hi all!
First post here, been lurking for a while...
I'm getting ready to hang my Pro1200x (replacing a Pro900x), and am curious as to whether or not I can switch this unit to 230v. I was feeding the Pro900x 230v, as it's a simple jumper change. But, the Zenith manual simply states that it's configured for 120v, and the Barco Cine 8 manual only says "Consult your dealer to switch...".
Any suggestions? (Many thanks, in advance!)
jantje112
| Posted: Sat Feb 14, 2009 11:25 am Post subject: |
On the most barco's it's a switch (and probably a fuse) on a little subboard close to the SMPS.
r.bauer
Joined: 08 Apr 2006 Posts: 280 Location: The Netherlands
| Posted: Sat Feb 14, 2009 11:31 am Post subject: |
| jantje112 wrote: | | On the most barco's it's a switch (and probably a fuse) on a little subboard close to the SMPS. |
On the most barco's it's a jumper (and probably a fuse) on a little subboard close to the SMPS.
Take the jumper out, rotate it and put it back in.
| Posted: Sat Feb 14, 2009 3:21 pm Post subject: |
It is a small AC input board, beside the SMPS, not the sub board on the SMPS.
kal Forum Administrator
Brian C
| Posted: Sun Feb 15, 2009 5:25 am Post subject: |
Thanks for all the help, guys!!
I knew I came to the right place....
| Posted: Sun Feb 15, 2009 5:32 am Post subject: |
Why not just use 120 ?
