Moome sync issue with BlueRay discs
deewaan1
Posted: Fri Jan 30, 2009 10:29 pm    Post subject: Moome sync issue with BlueRay discs
Hi. I just recently set up my Marquee 8500 with a Moome 1.3 card. I'm using a PS3 for my input. Games play fine through the HDMI input as well as regular DVDs. Problem is when I play a BlueRay disc I get a SYNC? message displayed on the screen and the picture is completely distorted. Just colored lines moving diagnally all over the screen. I have tried all of my BlueRay discs to see if any work and all have the same problem. I've gone through all the paperwork I've printed off and can't find anything that will help. Hope someone here has solved this same issue. Thanks in advance!
Posted: Sat Jan 31, 2009 1:01 am    Post subject:
Can you set up the PS3 to output 1080p@60 if its going to 1080p@24 CRT PJ cant sync to that low a refresh rate. Not sure how PS3's work in that regard.
Posted: Sat Jan 31, 2009 1:03 am    Post subject:
Yes set 24Hz from auto to off in the pS3 menu.
deewaan1
Posted: Sat Jan 31, 2009 2:51 am    Post subject:
That was it! Thanks you guys are great! I was kinda wondering about that because in the HDMI V1.3 datasheet it mentions that most CRT projectors only support 30HZ-150HZ. I wondered if the output was different for the BlueRay as compared to the regular DVD. But I didn't know how find out what the PS3 puts out for HDMI or how to adjust that in the PS3. But it was pretty simple to change in the video setup menu once you knew what to look for. Thanks again. Everythings running great. All I might have to do is adjust the gamma settings but it looks great as is. Always room for some tweaking though.
Posted: Sat Jan 31, 2009 3:16 am    Post subject:
You are welcome.
Is there ever an end to the tweaking? When I first built my theater back in the day ( LD w/5.1AC3, Sony27"Trinitron,Yamaha/Paradigm 5.1 system ) my friends would get pissed at me because they would be trying to watch the movie and I would be tweaking. Finaly we can to an agreement I have untill the first credits roll to finish the tweaking. Smile
Ahhh the good old days.
