S-video input issue
marshmello822
Posted: Mon Jan 26, 2009 11:29 pm    Post subject: S-video input issue
Hey there,
I have a sony vph-1252q. I recently got an adapter peice that coverts component RCA yellow to svideo so that I can plug it into the projector. It works on my friends big screen but on the projector the image had no colors. The s-video works from a laptop but not from the wii to component to svid :/ Whats the deal? iS there anyway to fix this? Thanks in advance
-Marshmello822
Posted: Mon Jan 26, 2009 11:37 pm    Post subject:
Get a female RCA to Male BNC converter and just run the composite into the projector like this:
http://www.amazon.com/RCA-Jack-BNC-Plug-Adapter/dp/B0002KR09M/ref=tag_tdp_sv_edpp_i
OR at RadioShack:
http://www.radioshack.com/product/index.jsp?productId=2104082
For a much better picture from the Wii get a transcoder to convert the component to RGBHV ( if you have the card in your projector ) and you will get a nice 480P picture on the screen once you setup and align the projector.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=6860.html
You would hook up like this:
Wii===component.cables==RTC2200==RGBHV.cables===Sony
Posted: Mon Jan 26, 2009 11:43 pm    Post subject: Re: S-video input issue
marshmello822 wrote:
Hey there,
-Marshmello822
The word highlighted above should be COMPOSITE.
It's possible that some sources will gho to b/w when converting the composite signal to Svideo, I've seen that here before. If that's the case, then you'll need to use composite video to the projector rather than through the Svideo adapter.
Why not get a line doubler, that will improve both the video and Svideo signals on the 1252?
Posted: Mon Jan 26, 2009 11:47 pm    Post subject:
Nice catch. I read too fast.
