desperately seeking advice
moby
Posted: Sun Jan 25, 2009 12:39 pm    Post subject: desperately seeking advice
Hi everyone. I had my technician work on marquee 9500 lc ultra and we experienced a couple of problems which we cant figure out!
Things that we experienced when installing the projector:
When using the HDMI input, the picture was overscanned In both sides with no possibility to get it right.
The picture was bigger than the picture, and it was possible to move the picture inside the picture.
It looks like a blanking problem, but all blanking was off.
It was not possible via the remote to get In touch with any setup or adjustment on the HDMI board.
When going SD in via the component input, there was no overscan.
also the setup has been set to make the picture show 1080p but during a ISF calibration the picture showed that it was only a 1080I.
Even though we made a ISF calibration i feel that some of the dark scenes are much to dark this is what I imagine can be adjusted with the gmma x remote but as I stated the remote is not working.
Im using a bluray player connected to a vp50 which then connected to the marquee
Ive installed a multi input VIM card into the projector!
Any advice is appreciated!
http://www.curtpalme.com/forum/viewtopic.php?p=171911
Posted: Sun Jan 25, 2009 6:16 pm    Post subject:
I'm assuming you have blue ray into the HDMI in which case overscan is normal because of the porch sizes on Blue Ray and even HD-DVD had this. You need a video scaler to adjust it or you can just not worry about those last 5 centimeters on the sides. I don't think there's anything really important in the movie happening over there. Wink
moby
Posted: Tue Jan 27, 2009 3:34 pm    Post subject:
Im not sure what a video scaler is. Is it like the vp50 I already have or? Any Idea about why my remote isnt working for the gamma or why my picture isnt showing a 1080P picture?
Posted: Tue Jan 27, 2009 3:41 pm    Post subject:
I've got a couple of suggestions:
1) Read the manuals for the set and the VP50, it sounds like it's been plugged in without anyone really knowing what it does. The VP50 is the scaler.
2) Not sure of the qualifications of the technician you have, but it sounds like he might be more familiar with digital sets over CRT. (that's very common nowadays). I'd post your location here, and see if someone more familiar with CRTs can assist, even if they are not ISF certified.
I'll bet the above sounded a bit rude, but that's not what I wanted it to read. You've got the right equipment, you just need to know how to use it. The more you as the end user end up learning about the set, the better off you'll be.
Cheers!
moby
Posted: Tue Jan 27, 2009 3:50 pm    Post subject:
Thanks Curt!
And your right my technician is more into DLP but has had some experiences with CRTs. We did try everything with the scaler but couldnt figure it out! Im getting quite frustated with the whole thing. The problem is I live in Denmark, and I dont know if there are to may here that can help me!
moby
Posted: Sat Jan 31, 2009 11:26 pm    Post subject:
BUMP
I still without a solution to my problem. Can anyone atleast tell me, if the remote I got for my VIM hdmi card with gamma x, how does it work because Im not sure what its suppose to do. Nothing happens whatever you press on it. Is it defective or what. I was assuming that some sort of menu would pop up but im not in luck with it!
Posted: Sat Jan 31, 2009 11:57 pm    Post subject:
you have to learn how to adjust the timings for the VP50 to get the image to fit correctly. Or you can try the long and short retrace in the marquee menu, but i doubt you'll get any better results. You neeed to use the VP.
The moome card does work, read through this thread:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=14305.html
there is some info on how to do the gamma and the remote.
1031
Posted: Sun Feb 01, 2009 10:19 am    Post subject: Re: desperately seeking advice
You need to do "user" resolution from standard resolution thats found at VP-50 output menu. Firts there were adjust that needs to set to "advanced" (found at: menu->config.->user mode) then you can do "user" resolutions from standard 1080P. You must adjust horizontal front-/back porch values until picture fits to screen. Do that with conjunction marquees picture size/phase/blanking adjustments-> first adjust size allmoust max at marquees menu, open side blankings->set phase to mid point-> pull up testpattern from VP-50 (Frame geometry) ->go to VPīs output menu-> format->1080p60> adjust hor.front-/backporch until you can see those picture area lines. When you have adjusted that format comes that "user" format.
Then fine tune with phase(marquee) and horzontal shift(VP50) and dont forget to adjust blankings! and also check that picture still fits on tubeīs face, you dont want to run picture area over tubes edge!
Save that "user resolution" to disp.profile (read also how that display profile works....)
And save that also to marquees recall memory.
That prosedure should work.
I use different disp.profiles for different framerates, so ie. 1080p@60hz has own profile then 1080p@48hz is in different profile.
Here are timings from my setup (VP-50+E-home M8500) 1080P @ 59.94Hz
H-shift=235
H-Size=1920
H-front=183
H-Sync=44 ( maybe is better use wider sync..Mine does work quite ok with this..)
H-Back=235
V-Shift=28
V-Size=1080
V-Front=12
V-sync=5
V-back=20
DVDO VP-50
New hobby, Rally
r.bauer
Posted: Sun Feb 01, 2009 1:16 pm    Post subject:
1031 is spot on!
Once you have Blu-Ray playback perfected at 1920*1080@60hz on your marquee, you can start tweaking the set more by feeding it 1920*1080@71.93hz or 1920*817@71.93hz and see if you like that better for film playback.
Short explanation about porches: Porches can be looked upon as 'pixels' but they don't contain any video information. They are required to be in the signal to allow the electronics of the projector to function optimal. Analog display devices just need more porches than digitals to perform than properly. Just add more porches (pixels) in the front- and backporches and you will see more of the picture. Back porches are added on the left side of the image and front porches are added on the right side of the image.
The VP50 probably also has a gamma control, and that may be preferred over the gamma control in the HDMI input board.
ilias
Posted: Fri Feb 20, 2009 12:53 pm    Post subject:
the scaler VP30 options not work for me, i have to turn the G70 from the base, 10 cm right!!!
Posted: Fri Feb 20, 2009 1:30 pm    Post subject:
Are you meaning that you cannot adjust timing parameters ? Like h-front porchs
I had vp-30 before and it allows you to create custom resolutions, did you changed that usermode to advanced?
But for hd-material that Vp-30 was pretty useless, it cannot do real framerate conversation (like 24p->48/72) But it allows still do custom timings for "passed trought"
Edit.. Little corrections.
DVDO VP-50
New hobby, Rally
ilias
Posted: Sat Feb 21, 2009 7:55 am    Post subject:
It work! resolution 1570X1080/72Hz, but not ok for me, i prefer 1920X1080/60Hz !
