What other lenes are a stock bolt on a Sony D50?
Posted: Thu Jan 22, 2009 6:20 am    Post subject: What other lenes are a stock bolt on a Sony D50?
What other lenses will bolt on a Sony D50 with no modifications necessary?
kschmit2
Posted: Thu Jan 22, 2009 7:54 am    Post subject:
what comes stock on them?
Loudmouse
Posted: Thu Jan 22, 2009 7:04 pm    Post subject:
Mine say HACC/HD-6
Posted: Thu Jan 22, 2009 7:12 pm    Post subject:
If the HD-6 is stock the HD-144/145 will also fit stock.
Posted: Thu Jan 22, 2009 7:16 pm    Post subject:
Ooooooo interesting.
Posted: Thu Jan 22, 2009 7:40 pm    Post subject:
I don't see why you'd want to change, short of changing the throw distance slightly. The HACC lenses are very good, and the tubes are already color corrected.
Posted: Fri Jan 23, 2009 12:40 am    Post subject:
I was just wondering is all. So the D50's had different bolt patterens then the 12xx series.
Posted: Fri Jan 23, 2009 12:46 am    Post subject:
They are 7" tubes, so yes, they are the smalelr HD6/144/145 bolt pattern.
Analog_Alpha
Posted: Fri Jan 23, 2009 8:41 pm    Post subject:
Analog, are you looking at a D50 that's for sale with 200 hours, that's local to you? Wink
Alpha
Posted: Sat Jan 24, 2009 2:59 am    Post subject:
My girlfriend has a D50 and I want to move it further back in the room. I wonder if the HD6's or HD145's would have a longer throw?
kschmit2
Posted: Sat Jan 24, 2009 9:50 am    Post subject:
IIRC both should be pretty much identical wrt throw distance. I didn't have to move my mount between a GP3000 (HD6C ML) and PG6100 (HD-145)
Posted: Sat Jan 24, 2009 10:33 am    Post subject:
Thanks. Then I don't think I'll bother with the HD145's
