posde
| Posted: Wed Jan 07, 2009 3:18 pm Post subject: Runco DTV-1100 and 230V PSU |
Hello,
first post, please be gentle
I have recently acquired two Runco DTV-1100. One of them stays in the US, the other is in Germany.
Next to the power socket is a small label that says 110V/230V. I can't find any place where to change the projector from 110 to 230V. At the moment, when I turn on the PJ, it blows the fuse in the rocker box, but lights up the red standby light.
Does anyone have information, whether or not I need to change a jumper or something, or if it is automatically detected.
Any and help is greatly appreciated.
Best regards
Oliver
posde
| Posted: Wed Jan 07, 2009 3:25 pm Post subject: |
Curt,
thanks will check right away.
Gosh! that was fast.
Best regards
Oliver
posde
| Posted: Wed Jan 07, 2009 3:33 pm Post subject: |
Yes, that was the place I could not find.
Now I just need to find the corresponding fuses someplace.
Thank you.
Best regards
Oliver
posde
| Posted: Wed Jan 07, 2009 4:10 pm Post subject: |
OK, now the fuse in the rocker box no longer blows.
Unfortunately, I've probably destroyed something within the projector, as I no longer have a Standby lamp
What is the procedure to check out what board I have destroyed?
Oliver
_________________ Some details on my odyssey can be seen at http://possy.de/runco/
posde
| Posted: Wed Jan 07, 2009 4:11 pm Post subject: |
Interesting, the picture on page 6-2 of the 1209s manual says two 5A fuses, page 6-3 talks about two 6.3A fuses. What is correct?
Ile
| Posted: Wed Jan 07, 2009 4:19 pm Post subject: |
From BG1209s service manual
5A for 230V
10A for 120V
Same info should be printed to board.
Smaller Barcos use 4A/6,3A.
posde
| Posted: Wed Jan 07, 2009 4:20 pm Post subject: |
Ile,
do you have a Runco service manual, or the Barco 1209s service manual?
rgds
Oliver
Ile
| Posted: Wed Jan 07, 2009 4:25 pm Post subject: |
BG1209s
posde
| Posted: Wed Jan 07, 2009 4:30 pm Post subject: |
I have the 1209s Install manual here. And the calls for 5A on one page, and 6.3A one page later (pg 6-3).
I will now keep the unit powered down for the night, and see what happens tomorrow morning.
Thanks for your hints.
rgds
Oliver
posde
| Posted: Thu Jan 08, 2009 2:33 pm Post subject: |
Turned on the projector this morning. No luck.
Checked two more fuses in the cards, both checked out ok.
What to do?
Check out the new fuses. Oh, one of the two new fuses on the AC board is shot. Hmm, ok, get new ones.
Check new fuse, new fuse is ok. Plug the new fuse into the ac board. Plug in the power cord.
Press the power on button.
Stdby light comes on red
Press the Stndby Button on remote.
BINGO - I get a picture.
Now off to check the size of the picture. Unfortunately no label on the lenses , but at least I can check out the picture width. And see if I can get rid of the burn-in by moving the raster away from it. And then off to get some new C-elements for red and green.
Thank you very much for all your help guys! I will keep you posted.
rgds
Oliver
posde
| Posted: Thu Jan 08, 2009 5:42 pm Post subject: |
The next problem came sooner than expected.
Green tube lights up, blue tube lights up, red tube ... does not light up
hmm, turn off the projector, unplug the power cord, turn on the projector to empty out most of the power. Open top of the case, and hope that something is loose from the journey (it is a long way from the east coast of the US to the west coast of Germland). Press a bit on the neck board - ooh - something happened.
Put everything together, plug in the power cord, and ...
the green tube lights up
the blue tube lights up
the red tube ... LIGHTS UP
More playing.
| Posted: Thu Jan 08, 2009 9:04 pm Post subject: |
Gees you need to be careful.
You are blindly playing with fire.
You will spot burn a tube fiddling like that...
posde
| Posted: Thu Jan 08, 2009 9:13 pm Post subject: |
| Mark_A_W wrote: | Gees you need to be careful.
You will spot burn a tube fiddling like that... |
You are absolutely right.
The whole deal was an accident, as I never would have thought to acquire a Runco DTV-1100 for 999USD. Adding up shipping and customs the price ended up at around 1800EUR, still fairly low.
With my NEC PG6 I was too afraid to open the chassis, with the Runco I was so disappointed by things not working out, by a burn-in that the seller did not talk about, about coloured C-elements which have bumps like someone tried a soldering iron on it, with broken hinges from the transport, that I really let go of all precaution.
There is a mask on each of the tubes, but mainly visible on the green one, as can be seen on my page about my journey.
I will invest what needs to be invested into this set. And I will succeed.
rgds
Oliver
| Posted: Thu Jan 08, 2009 10:33 pm Post subject: |
Forage ahead Oliver! You'll get there in the end.
Ile
| Posted: Fri Jan 09, 2009 9:55 am Post subject: |
| posde wrote: | | coloured C-elements which have bumps like someone tried a soldering iron on it, with broken hinges from the transport, that I really let go of all precaution. | Sunshine into lenses burns c-elements just like that.
Good luck to find new ones, 3M don't sell those anymore. You should try to find good green tube with c-element. Red c-element you can take from some burned/shorted cheap tube. Check also Sony 1292 red tubes.
I have similar but beige hinges from BG1200. You get those free if you pay shipping.
posde
| Posted: Fri Jan 09, 2009 10:30 am Post subject: |
Ile,
I'd appreciate that a lot. As the pictures show it, I really need only the bottom hinges, but appreciate a full set none the less
Send me a PM with your details so I can send you money, once you've found the hinges.
rgds
Oliver
