benareeno
| Posted: Sun Jan 04, 2009 11:29 pm Post subject: Barco neck board... |
I'm assuming the light must always be lit? I noticed that the blue tube neck board is usually lit, but sometimes not lit...I also notice the odd issue with the blue tube in low light material. Is this a bad neck board or something else in the chain?
barcoguy
| Posted: Sun Jan 04, 2009 11:44 pm Post subject: |
Adjust the G2 setting. Its a board in the back half of the projector.
1. Let the projector warm up for ~30min
2. Go into the service menu under g2 adjustment.
3. SLOWLY turn the pots until the neckboard led goes out.
Its has 3 small RGB pots
http://www.curtpalme.com/Barco808_Layout7.shtm
Gary M. Guest
| Posted: Mon Jan 05, 2009 12:29 am Post subject: |
should the lights on the neck cards be lit when not in G2 adjust mode (normal operation)?
-Gary
huggy
Joined: 02 Aug 2008 Posts: 927 Location: Melbourne,Australia
| Posted: Mon Jan 05, 2009 1:13 am Post subject: |
As far as I know and this is what I've been told,the led's should light up at start up and all three should turn off after a short while.If the led's are coming on and off during normal operation then g2 needs adjusting.
benareeno
| Posted: Mon Jan 05, 2009 1:45 am Post subject: |
so, the proper adjustment is to adjust G2 until the light goes off, not stays on?
huggy
| Posted: Mon Jan 05, 2009 1:49 am Post subject: |
As stated,go into service mode/G2 adjustment,hit enter and then turn each pot on G2 board very gently until each led turns off,when all three are off g2 is done then you can exit menu.
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Mon Jan 05, 2009 4:23 pm Post subject: |
The lights (green LED) will be off for normal operation is they have the G2 set properly.
_________________ Engineer by Day
Photographer by Night
My Portfolio
Gary M. Guest
| Posted: Mon Jan 05, 2009 10:07 pm Post subject: |
| Z-Photo wrote: | | The lights (green LED) will be off for normal operation is they have the G2 set properly. |
thats what I thought, thanks
-Gary
