Barco discrete IR codes
Gary M.
Posted: Sat Jan 03, 2009 9:58 pm    Post subject: Barco discrete IR codes
I have searched a plenty and came up with nothing
are there discrete on and off IR codes available for the Barco CRTs, 1209s here Wink
thanks
-Gary
Cousin.It
Posted: Sun Jan 04, 2009 3:42 am    Post subject:
If you look in the files section at http://www.remotecentral.com/ you might derive what you're looking for. The Barco remotes use a less-typical modulation technique so most inexpensive programmable remotes won't work, but there are a few that do, but its a pain if you wanted to program all the different buttons. That web site has a bunch of pre-generated files for the Pronto people have contributed.
Mark
Posted: Sun Jan 04, 2009 3:46 am    Post subject:
Also see this...
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?kw=Barco+&st=1&area=&db=&br=&dv=&dt=&so=
Hi Mark Wink
dormie1360
Posted: Sun Jan 04, 2009 5:25 am    Post subject: Re: Barco discrete IR codes
thanks
-Gary
If memory serves me correctly I used to have some ....I used them before I went serial. I'll look around, not sure if I'll find them. As someone mentioned they are high frequency PPL commands and are kind of a PITA to work with. I can't remember if the power commands were address specific or not. What format can you use?
Also, don't the numbers associated with the ports act as discrete power on?
Regards,
John
Posted: Sun Jan 04, 2009 5:42 am    Post subject:
You mean this post ?
Found the problem! Embarassed The Barco address is 1. The crestron module assumes 0. Simply had to add a step to switch to 1, when I access the Projector pages on the touchpanel. Thumbs Up Thanks for your help jkv. Can put the Barco remote in storage! Always seems to be the simplest oversights that cause the greatest headaches.
Gary M.
Posted: Sun Jan 04, 2009 7:42 pm    Post subject:
my previous Barco 808s worked fine with a pronto tsu2000
I am currently using a URC MX900, it has alot of control over the IR signal output
has anyone connected a IR block output to the Barco IR in port? should work no?
-Gary
Posted: Sun Jan 04, 2009 8:46 pm    Post subject:
-Gary
Gary, with all that fancy a$$ $hit you have, why don't you just break down and install a real HT automation system like Tom has. He has a Crestron system and rumor has it that he even programmed it himself Wink
Gary M.
Posted: Sun Jan 04, 2009 9:10 pm    Post subject:
Chip, I have a pretty fancy remote setup including a MX3000 but sold it
I am thinking of getting a MSC400 right now as well, which adds all sorts of capability
but if I did have stuff all over the house and multiple systems you bet I would have a crestron setup Wink
-Gary
dormie1360
Posted: Mon Jan 05, 2009 1:13 am    Post subject:
Sorry couldn't find the codes. Crying or Very sad I'm pretty sure I got them from either a pronto file at Remote Central, or from URC's database. I hunted around in both places today and couldn't find them.
Never used the IR block on the CRT. I should mention that I've use a lot of URC stuff with the Barco, including the MX900. I have never been able control the Barco with any of the newer URC narrow band remotes, (This includes the 900) via RF using one of their RF-IR boxes. This goes back to the issue with the type of IR codes Barco uses. The older URC Wide band remotes worked fine. I just mention this in case you were thinking of going down that path.
You mentioned the MSC400, which is what I'm now using with the MX3000. Because the IR codes "reside" in the MSC400 and not the remote, you shouldn't have the RF issue, although if you do get a MSC400 I'd highly recommend the RS232 connection for your Barco. Many more control options and discrete codes.
Anyway just my .02 cents.
Regards,
John
Posted: Mon Jan 05, 2009 5:14 am    Post subject:
"I'd highly recommend the RS232 connection for your Barco. Many more control options and discrete codes."
That's why I suggested he move onto a real automation system. So much neat stuff (ir, rs232, contact closures and more), all with the press of a single button. Not to mention how slick it is to see that big touch panel on the coffee table. Everything that is automated in my house can be accessed from the theater panel. Heck, one button tap and I can view my video security system from my projector and a second tap to turn on the irrigation system if I don't like who's at the front door.
Posted: Mon Jan 05, 2009 5:49 am    Post subject:
Hmmm I always like the manual way of doing it. I have 20 remotes and a dozen power buttons to push. It just suites the mad scientist in me Twisted Evil
Gary M.
Posted: Mon Jan 05, 2009 8:29 am    Post subject:
Regards,
John
now you done it John, a MSC400 goes on my to do list Thumbs Up
how is URC with RS232 codes in their msc400 database/software? , about a year ago I heard it was pretty slim
EDIT:just checked out the software, seems to be quite a few devices in there, most of my gear has RS232 as well Wink
this or that would be nice as well:
http://www.smarthome.com/4832/X10-RF-Receiver-to-RS-232-Adapter/p.aspx
http://store.homeseer.com/store/TI103---X10-Computer-RS232-Interface-ACT-HomePro-P20C113.aspx
-Gary
dormie1360
Posted: Mon Jan 05, 2009 1:44 pm    Post subject:
The database is okay, but it could be better....I used it for Sony's DVD changers and found out the commands provided were not complete strings, I had to hunt down Sony's serial protocol documentation to figure it out. Having said that I've had no problem getting serial commands. Barco sent me theirs.
Regards,
John
Gary M.
Posted: Sun Mar 22, 2009 2:36 pm    Post subject:
humpty bumpty, I now have a MSC-400 which I am currently working on, this thing is so awesome, I have alot of trouble with the RF transmission so the digital trigger usage on my MX900 with everything stored in the MSC-400 is lovely
John, I sent a PM for that Barco RS232 data, that would be a huge help
thanks
-Gary
dormie1360
Posted: Sun Mar 22, 2009 8:03 pm    Post subject:
Gary,
I sent you some files. Let me know if you didn't get them.
Regards,
John
secstate
Posted: Mon Mar 23, 2009 12:59 am    Post subject:
Gary do not forget that your Barco will use the newer IR Barco codes since your Runco is newer than mine and mine has the newer codes as well. So a lot of the stuff you see on the net is for the older Barco IR codes. Also note that the newer IR should be more easily supported by universal remotes (that was why Barco changed supposedly).
