benareeno
| Posted: Wed Dec 31, 2008 4:34 pm Post subject: This barco is fun...picture is on...picture is off...etc |
I took the r and b tubes out for glycol...put them back in and the picture comes on for 3 seconds then off for 3...and this continues and I can't get a constant pic.
I do suspect my vga cable or something to do with the synch connectors...it seems that touching those cables enabled me to get a picture...but now touching them further doesn't help me to get a better picture.
3 seconds on 3 seconds off...and when off, the blue tube has noise, the r and g are blank.
Projector has been unplugged in my somewhat cold basement for the better part of 2 weeks now...could that be a factor?
Removing and re-installing the tubes seemed quite straightforward with the G2 and neckboards being the only connections involved....but I guess I managed to foul it up somehow. Any thoughts?
Ben
jkruger
| Posted: Wed Dec 31, 2008 5:34 pm Post subject: |
I had a similar problem one time after removing the tube connectors on a sony. Turns out I had bent one of the pins on the tube. I straightened the pin and it worked fine.
benareeno
| Posted: Wed Dec 31, 2008 5:37 pm Post subject: |
I verified all the pins last night before I attached the neckboards....but I'll definitely check 'em again!
Ben
| Posted: Wed Dec 31, 2008 9:17 pm Post subject: |
I'm sure Pete will chime in and tell you it's that crap projector you got... No wait.....
| Posted: Wed Dec 31, 2008 10:33 pm Post subject: |
Just blink every 3 seconds
benareeno
| Posted: Wed Dec 31, 2008 11:25 pm Post subject: |
I checked the pins, and they were definitely fine....hmm. Any other thoughts?
| Posted: Wed Dec 31, 2008 11:33 pm Post subject: |
| garyfritz wrote: | I'm sure Pete will chime in and tell you it's that crap projector you got... No wait.....  |
Now hold on there buckeroo. I think I know what you're getting at. You were not thinking that I......no you would have no reason to think that.
_________________ Chip
| Posted: Wed Dec 31, 2008 11:40 pm Post subject: |
Ben,
Can you access the menu's? Do they go on and off too or is it just the input signal?
benareeno
| Posted: Wed Dec 31, 2008 11:48 pm Post subject: |
I can sometimes get at the menu...but not staying on the screen. If it comes up, it's gone just as quick. And, when I power off the projector, it goes off and comes right back on.
| Posted: Thu Jan 01, 2009 5:43 am Post subject: |
| stefuel wrote: | | garyfritz wrote: | I'm sure Pete will chime in and tell you it's that crap projector you got... No wait.....  |
Now hold on there buckeroo. I think I know what you're getting at. You were not thinking that I......no you would have no reason to think that. |
Happy New Year Chip !
| Posted: Thu Jan 01, 2009 2:35 pm Post subject: |
| Tom.W wrote: | | stefuel wrote: | | garyfritz wrote: | I'm sure Pete will chime in and tell you it's that crap projector you got... No wait.....  |
Happy New Year Chip !  |
And the same to you.
But while we're on the subject of broken Barco's, he wouldn't have that problem if he owned a AmPro. In fact if it were a 4600HD, he'd have no problems
Ile
| Posted: Thu Jan 01, 2009 9:53 pm Post subject: |
First check those tube grounding cables from neck board to tube neck.
Remove neck board cables and hv cable from one tube at time to see if it run longer with just two tubes connected. Start from blue tube.
benareeno
| Posted: Thu Jan 01, 2009 10:08 pm Post subject: |
I'll bet it is one of those cables...One came loose during tube extraction, but I put it back together..maybe another came loose and I missed it.
Are you saying to fire up the projector without HV for R&G? Or just pick a tube and disconnect it from HV and neck board? Then plug that tube back in (if issue still exists) and then try the next tube?
| Posted: Thu Jan 01, 2009 10:12 pm Post subject: |
Seems to me that you're not losing HV if the pix is pulsing on and off. WHen it comes back, does the pix start large and out of focus, and 'zoom in' to then fill the screen, and comes into focus, or is this an instantaneous on and off? If it's instantaneous on and off, the HV is consistent, and it's some video problem. Check all connections, check the scan fail light on the G2 board. It could be a bad G2 board as well as a video issue.
benareeno
| Posted: Thu Jan 01, 2009 10:35 pm Post subject: |
I took the tubes out, but I'll put them back in later tonight.
Curt, I think the pic was bigger and got smaller, but I can't be certain. I'll report back later.
Thanks guys!
Ben
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Fri Jan 02, 2009 2:50 pm Post subject: |
Happy new year Chip.
recheck all of your cable connections -
_________________ Engineer by Day
Photographer by Night
My Portfolio
benareeno
| Posted: Sun Jan 04, 2009 9:04 am Post subject: |
I actually did break one of the ground wires (the green tube), but I resoldered it and still an issue! Then I simply had to adjust the image to one side via the htpc controls and I was good. No more blinking picture! I noticed an i2c error at 86h, i searched the forum and saw that it had to do with horizontal position...so that's why I moved it in the htpc.
I'm pretty stoked as I thought I was done with this thing...and I wouldn't pay to ship another one here at this point.
I do however still have an issue or two...the main one now is that if I simply touch the builtin remote, the pictures blinks off for a second or two. I think the screen shows an invalid key entry error. Do people have major issues with this thing? And when I say touch it, I mean just that...if I gently touch it, the screen will blank.
I have also noticed that the light on the blue neckboard is sometimes off...
Wow...it's amazing how many things can go wrong with these things these days. I guess touching the remote on the projector is no biggie, but the light on the blue neckboard is a bit disturbing. Any ideas what that is?
Ben
