| Posted: Tue Dec 30, 2008 1:59 am Post subject: OK Marquee guys, I have a question |
This is for the LC Quees.
Have any of you run into a problem where when you bolt on a HD-10 lens to the coupling that is working perfectly and after snugging up the screws, the center focus binds to the point that you can't turn it. If you remove the lens from the coupling, it spins perfectly? Is there something keeping this from seating correctly and tightening it distorts the lens enough to make it bind? This is on Heywoods 9500LC that has just gotten new fluid and bellows changes. To give you a idea how bad it binds, he snapped the lock nut stud, pushing on it with his thumb while trying to adjust the lens. I have not looked at it my self but two lenses in the same position are doing the same thing.
_________________ Chip
| Posted: Tue Dec 30, 2008 2:26 am Post subject: |
Yep, the odd 9" lens seems to be really picky as to the roundness of the outside barrel. Given that you can tilt the lens in almost every direction with the Scheimpflug adjustments, it might be an idea to leave the one screw slightly loose. (flame suit on.. CONVERGENCE DRIFT, CONVERGENCE DRIFT!)
Heywood Jablome
| Posted: Tue Dec 30, 2008 3:07 am Post subject: |
I just can't imagine strain causing the binding... The Mechanical Engineer in me sees that conical form in aluminum and thinks "this is stiffer than Ron Jeremy at a fluffers convention." (Sorry for the visual boys! )
Tomorrow will be day two of "called-in during my last-chance, use-it or lose-it vacation." I hate my job. When/if I regain the time and strength I'll try to loosen all the screws and see if the things un-bind themselves.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
| Posted: Tue Dec 30, 2008 3:46 am Post subject: |
| Heywood Jablome wrote: | I just can't imagine strain causing the binding... The Mechanical Engineer in me sees that conical form in aluminum and thinks "this is stiffer than Ron Jeremy at a fluffers convention." (Sorry for the visual boys! )
Tomorrow will be day two of "called-in during my last-chance, use-it or lose-it vacation." I hate my job. When/if I regain the time and strength I'll try to loosen all the screws and see if the things un-bind themselves. |
Whats a fluffer?..........................
jkruger
| Posted: Tue Dec 30, 2008 3:48 am Post subject: |
I had one of the lenses on my 1100 bind when I was putting it on, and I found it went on better when I turned the center focus all the way out.
| Posted: Tue Dec 30, 2008 7:30 pm Post subject: |
Wow, , and I thought filcher was bad.
Gary the fact that you know that leads me to believe I don't know everything about you 20 bucks says you have a secret DVD collection in your HT not visible by casual visitors.
| Posted: Tue Dec 30, 2008 8:38 pm Post subject: |
| draganm wrote: | Wow, , and I thought filcher was bad.
Gary the fact that you know that leads me to believe I don't know everything about you 20 bucks says you have a secret DVD collection in your HT not visible by casual visitors. |
$30 says it goes back to the days of Betamax
Heywood Jablome
| Posted: Tue Dec 30, 2008 11:36 pm Post subject: |
| AnalogRocks wrote: | | draganm wrote: | Wow, , and I thought filcher was bad.
$30 says it goes back to the days of Betamax  |
Hmmm.... How old is Gary? If he's 40+, then $50 says it goes back to the days of 8mm!
| Posted: Wed Dec 31, 2008 12:07 am Post subject: |
Another perfectly good thread dragged into the gutter and only at curtpalme.com
| Posted: Wed Dec 31, 2008 1:12 am Post subject: |
Somewhere around here, I have a regular 8mm copy of Deep Throat. Only bits and pieces of it, a friend stole it from his bad back in 1980 and brought it over as I had/have an 8mm projector. Wonder if I should throw that on eBay???
Ohmess
| Posted: Sun Jan 11, 2009 2:18 pm Post subject: |
Dude -- if it goes back that far it would be VHS. Beta was a superior format back in the day, but the reason VHS won the format wars was that there was a lot more porn available on VHS.
Heywood Jablome
| Posted: Sun Jan 11, 2009 3:39 pm Post subject: |
| Ohmess wrote: | | AnalogRocks wrote: | | draganm wrote: | Wow, , and I thought filcher was bad.
Dude -- if it goes back that far it would be VHS. Beta was a superior format back in the day, but the reason VHS won the format wars was that there was a lot more porn available on VHS. |
True, but the same could not be said about hd-dvd!
