Accessing the hour meter on a DWIN?
Posted: Sun Dec 28, 2008 5:35 pm    Post subject: Accessing the hour meter on a DWIN?
I forget, how do you do it?
Posted: Mon Dec 29, 2008 12:24 am    Post subject:
2ndAnode (a Dwin expert) said:
While the projector is operating,
with a one second delay between
each keypress,
Press MENU, 9, 0, ENTER, 9, 8.
After collecting the information
press EXIT.
Posted: Mon Dec 29, 2008 1:10 am    Post subject:
Thanks!
sneeble
Posted: Mon Jan 19, 2009 2:13 am    Post subject:
Curt
My HD700 has 2377 hours, what is considered high hours?
Kind Regards,
Sneeble
Posted: Mon Jan 19, 2009 2:51 am    Post subject:
The P16 tubes that DWIN and later Barco 708/Cine 7 uses are strange beasts. Seems that they show a bit of tube wear earlier than other tubes, similar to the G90 from what I've read. Once the initial bit of wear is on the tube though, they seem to age about the same as other sets.
In DWIN hours, it seems that you're maybe at 1/2 life of the chassis. Since DWINs were only sold to home theater users, your hour count for a 6-10 year old set is about right. I don't think a DWIN in a commercial application of 24/7 would last 50K hours like a Marquee or Barco would. Then again, from what I've seen, I wouldn't trust a Sony G90 to last past 10K hours either chassis wise.
Mind you, maybe I should retract the above. I've never had a G90 or a DWIN that's been run 24/7, so maybe the light bulb theory applies to projectors as well..... leave the set on for 24/7, and they don't fail. a series of 2 hours on, 22 hours off every day leads to failures. SO what do I know? Smile
