marquee 9500+lose convergence
michael k
Posted: Sun Dec 28, 2008 11:42 am    Post subject: marquee 9500+lose convergence
it loses convergence everyday
its been unused fore two years
could it bee the battery?
Posted: Sun Dec 28, 2008 1:54 pm    Post subject:
It could be the battery, pull the CLM and measure the voltage if lower than 2 v it is in need of replacement. Also make sure you save the convergence after by locking the input your adjusting.
Posted: Mon Dec 29, 2008 4:54 pm    Post subject:
you never mentioned if this PJ is something you have owned or something you just broguht home. IF the latter, then It's mostl ikely your on a locked input or ASR is turned on. If it's niether of those then check the battery like described above.
michael k
Posted: Mon Dec 29, 2008 10:16 pm    Post subject:
i braugt it two years ago from a young man i gothenburg who died in a car accidant
and i had to much to do so it hasnt been setup until now
from tomorowe i will use a lamagen scaler
and i will use a dvicabel into a moomecard
Posted: Mon Dec 29, 2008 11:13 pm    Post subject:
That be MrKing i suppose, sad story. I hope you get it going.
michael k
Posted: Mon Dec 29, 2008 11:16 pm    Post subject:
yes mr king
and yes a sad story he was 27
michael k
Posted: Sat Jan 03, 2009 5:40 pm    Post subject:
draganm i think you are on the right track here
becouse i haven't set it up using the channels
before i hade a barco 1208 and i only used two resolution and it switched it automatically
i think i have to read in the manual
Confused
