Tech question, Mosfet
Posted: Thu Dec 25, 2008 10:27 pm    Post subject: Tech question, Mosfet
Can a mosfet be tested in circuit or does it need to be removed first? Surface mount mosfets ain't so easy to pluck off without damaging them. I'm trying to locate a dead short in a LCD monitor/touch screen back light power supply.
r.bauer
Posted: Thu Dec 25, 2008 10:39 pm    Post subject:
Sometimes they can be tested in circuit, especially when they are completely shortcircuit.
But you have to be carefull, sometimes when using your multimeter you can 'charge' the Gate enough so that it will simply conduct between the Source and the Drain, and the multimeter shows shows a nice short-circuit!
You first have to remove the charge from the gate and measure between the Source and Drain again.
Posted: Thu Dec 25, 2008 11:06 pm    Post subject:
OK, I want to make sure I'm doing this correctly Note: I'm not sure my DMM's diode test puts out the required 3-4 volt required to charge the gate. If not and I discharge the gate by touching it along with the source and drain with my finger, I should read open circuit between the source and drain, correct? With the gate charged, source to drain should be closed.
Posted: Thu Dec 25, 2008 11:36 pm    Post subject:
Hope this helps ...
http://www.4qdtec.com/mostest.html
http://www.uoguelph.ca/~antoon/gadgets/mostest.htm
Posted: Thu Dec 25, 2008 11:50 pm    Post subject:
Thanks Tom, that is the one I'm using.
I see no difference between the charged state and discharged state. Source to drain I read 3.76K
Posted: Thu Dec 25, 2008 11:52 pm    Post subject:
Sometimes they do need to be removed from the circuit as other resistors around it can come into play and give wrong or weird readings.
Heywood Jablome
Posted: Fri Dec 26, 2008 12:27 am    Post subject: Re: Tech question, Mosfet
Finally trying to fix my touchscreen that you blew up??? Razz Razz Razz
Posted: Fri Dec 26, 2008 12:33 am    Post subject:
It's actually a dual output power supply. Power is entered in the middle, goes through a 2 amp smt fuse (which is blown) then a capacitor and splits from there for the upper and lower back light power supplies. With the back lights unplugged, I still show a short within the supply. The LCD panel is producing a image as I can see it with a flashlight.
I have e-mailed the manufacturer for a replacement supply but thought I might kill some brain cells and find the short my self Twisted Evil
Heywood Jablome
Posted: Fri Dec 26, 2008 12:35 am    Post subject:
Any markings on the power supply board? I may be able to google up the spare...
Posted: Fri Dec 26, 2008 12:47 am    Post subject: Re: Tech question, Mosfet
I knew eventually I'd be asked something like that Laughing
If I can get it going, it would solve a lot of yout local monitor issues and give you a touch panel in the equipment closet for your Crestron work. It's only a 1024X768 panel but you could scale up 480I from your sources for the local stuff.
Posted: Fri Dec 26, 2008 1:01 am    Post subject:
On SMD's you can sometimes just unsolder 1 leg and lift it slightly to test the component.
Posted: Fri Dec 26, 2008 1:03 am    Post subject:
On the back there are two white stickers E153405 and l1502 lL 9912001906A
And on the front a board marking IL SSAN. ISI1502 REV.A
Posted: Fri Dec 26, 2008 1:07 am    Post subject:
Would it be a safe assumption that the one leg would be the gate? That way something could not back feed and charge the gate closing the connection between source and drain?
Posted: Fri Dec 26, 2008 1:36 am    Post subject:
Actually the correct way to test a Mosfet is to charge and unchagre the gate to make sure the device is working properly. I have found many a Mosfet's that were not shorted or open but the gate was not working properly.
Just for some FYI, some of these were on Ampro horz outputs........... Smile
Heywood Jablome
Posted: Fri Dec 26, 2008 2:07 am    Post subject:
Finding a lot of nothing so far... Can you post the manufacturers name and model number?
-edit: that was make, model of the finished LCD: most websites search for parts that way.
Posted: Fri Dec 26, 2008 4:56 am    Post subject:
You should also be able to short the gate to the drain and measure continuity between the source and the drain, If you get a dead short across it, then it's shorted.
Mind you, if a bypass capacitor on the power supply rail has shorted out, it will seem like almost everything on that line is shorted. I really doubt that surface mount MOSFETs are the cause of your dead short. Check bypass caps, I've had those short out on boards, and when they short, they really do get very close to 0 ohms. Usualy a bitch to find. Start with the large semiconductors and work down to the smaller ones is my rule of thumb.
Posted: Fri Dec 26, 2008 8:44 am    Post subject:
Advan Model #AGM15TK-TE Ser#H99520196 (1011U) P.D. Dec 1999
Heywood Jablome
Posted: Fri Dec 26, 2008 12:54 pm    Post subject:
These guys have a number of universal inverters for industrial LDs:
http://www.lcdparts.net/UInverter.aspx
Posted: Sat Dec 27, 2008 11:25 pm    Post subject:
I lifted the mofsets off the board to test them out of circuit. They seemed to be doing just what they're supposed to do. Then I put my dmm on the output of the blown 2 amp smt fuse and ground with the mofsets still off the board, I still had a dead short. WTF. Then I remembered what Curt said about bypass caps. I popped the first cap in the chain and short gone. I didn't have the right size cap to replace it with so for $hits and giggles I put in the closest one I had and it worked.
Thanks Curt
Heywood Jablome
Posted: Sun Dec 28, 2008 11:56 am    Post subject:
Lemme know the size of the cap (and fuse) and I'll raid the office stores.
