DVE versus AVS 709 greyscale readings...
cvearl
Posted: Sun Dec 21, 2008 9:14 pm    Post subject: DVE versus AVS 709 greyscale readings...
Sorry. One more thing...
Using different disks results in slightly different readings which is expected but DVE HD and AVS 709 are VERY close but have a look at the 30 IRE in the RGB ... There is a big difference in the RGB reading at that spot sepcifically. Will that have a large effect on changes the user tries to make?
See attachements...
NM... I just noticed they are not all that different. The one I was comparing to was something else and I mistakenly thought it was the AVS one. Initially I thought the RED was way different at 30 IRE between these two disks. I was wrong.
Thanks.
C.
DVE 6052.chc
DVE based greyscale readings
 Filename:  DVE 6052.chc
 Filesize:  14.44 KB
 Downloaded:  11 Time(s)
AVS 6052.chc
AVS based greyscale readings
 Filename:  AVS 6052.chc
 Filesize:  14.46 KB
 Downloaded:  9 Time(s)
