ordinho83
| Posted: Fri Dec 19, 2008 8:30 am Post subject: BARCO Cine 7 - Problem with red convergence |
Hi friends,
I have a problem with my Barco Cine 7 using internal or genlocked patterns.
I replaced my broken output convergence board with a new board of Curt Palme, yesterday. The new board work fine, and i solve my old problem!
Now, I'm setting the convergence of the proiector.
My problem is with red on green convergence. The red pattern is wrong too and I can not overlap with the green pattern.
I think that the red has a problem, but I do not know what.
I haven't problems with blu on green convergence; it work fine.
Help me please!
Regards
| Posted: Fri Dec 19, 2008 1:39 pm Post subject: |
Can you give me more info:
1) Does the center square move the red grid? (it should, that's got nothing to do with the convergence output board)
2) Do you get error messages when you move squares other than the center one? Does it move in ANY direction?
I did test the board here before sending it, so it should be OK. You might have convergence driver board issues.
ordinho83
| Posted: Fri Dec 19, 2008 4:13 pm Post subject: |
Hi Curt,
the square work good an I haven't error messages; I can move all the controls, now.
I have just do fine the convergence blu on green.
I think that the red raster is too large infact the corners are out of the tube.
Tnks
| Posted: Sat Dec 20, 2008 2:59 pm Post subject: |
If that's the case, make sure the main yoke is butted right up against the tube neck. Chances are it's slipped back a bit. There is a red V height adjustment screw on the deflection board, same with the blue. It's the little blue trimpot close to the V yoke connectors. THe red adjustment has a red dot on it, the blue does not. Green is the reference, it does not have an adjustment.
