StylinLP
| Posted: Fri Dec 12, 2008 11:22 pm Post subject: Selection switch on card and remote |
Hello, i have a Moome card with the HDMI 1.2 input and Gamma curve option and Remote control.
I guess the selector switch on the card is self explanatory. If you want to use an HDMI cable you switch the switch to the left. If you use Componant cable you switch the switch to the right. The instruction do not talk about this switch at all.
What happened when you are using both connections at the same time? I have my Cox Cable HDTV box connected with Componant cable and my Samsung 1400 with HDMI cable.
The Samsung does not display an image at all as long as I have the componant cables connected. Doesnt matter which direction the switch is in. Soon as I disconnect even one of the Componant cables I get an HDMI image from my Samsung BluRay player.
Any idea's what is wrong? Pressing the buttons on the remote control does absolutely nothing. But then again, I never has both sources running at the same time.
_________________ *Analog fans may be blind, but digital fans are deaf*
StylinLP
| Posted: Mon Dec 15, 2008 4:24 pm Post subject: |
It's working now. THanks
moome
| Posted: Tue Dec 30, 2008 4:37 am Post subject: |
hi, the switch on the card set the input priority when both hdmi and component input is valid,
if you want to use remote to change input source, you need set the switch at hdmi side~
