JEAN-HENRI
| Posted: Wed Dec 10, 2008 12:15 am Post subject: bg 1208 and bluray pana 55 |
what is the best connextion for my bluray and my bg 1208
the pana 55 has hdmi and component output
what has need for 1080p
excuse-me but i am a french man and i don.t weel speak .
benareeno
| Posted: Wed Dec 10, 2008 12:48 am Post subject: |
You could get the Moome external hdmi converter available on this site...probably your best option. $320, here's the link http://www.curtpalme.com/EXT-FULLHD.shtm
jask
| Posted: Wed Dec 10, 2008 9:25 pm Post subject: |
Or the HDFury 2 If all the bugs have been worked out.....
Person99
| Posted: Wed Dec 10, 2008 9:35 pm Post subject: Re: bg 1208 and bluray pana 55 |
| JEAN-HENRI wrote: | | what is the best connextion for my bluray and my bg 1208 |
What 1208 model (there were several):
1208 (rare only made for 8 months):
1208/2
1208s
1208s/2
1208se/2
Depending upon the model, it might not do 1080p well.
If the pana 55 component output is good, then you could also use a component transcoder (unless you have a later barco then it may just take component input).
| JEAN-HENRI wrote: | | excuse-me but i am a french man |
We all have challenges to overcome, yours is just a little greater than most.
_________________ Dave
JEAN-HENRI
| Posted: Thu Dec 11, 2008 5:24 pm Post subject: |
i have 1208
My pj is located in my basement (my ht)
My bluray is in my level and is connected to my HDTV (LCD SHARP)
I Want connected my bluray to my pj with component (because HDMI CABLE is not long)i think is the best option for me
I repeat the question «what is the best connextion for my bluray and my bg 1208»
my pj 1208 might 1080p well?
thank for yours reply
benareeno
| Posted: Thu Dec 11, 2008 5:56 pm Post subject: |
who cares about 1080p? Send it 1080i via hdmi....buy the moome box I showed you above. THat's your BEST solution.
If you want to save money, then use component video and run 1080i. Someone could probably sell you a component transcoder at a very good price.
Ben
Person99
| Posted: Thu Dec 11, 2008 6:07 pm Post subject: |
| JEAN-HENRI wrote: | i have 1208
thank for yours reply |
Are you SURE it is just a "1208"--that is what the tag on the back says? What is the "art" number on the silver tag?
You PJ most likely won't do 1080p very well, but can look very good at 1080i and the differences are minimal.
All the options were pretty much said:
1) Get a component to RGBHV transcoder
2) Get an HDMI/DVI to RGBHV converter (HDFury or Moome)
Number 2 is more future proof and generally has a bit better picture quality than number 1 because the DAC in those devices is better than the DAC in the source device.
JEAN-HENRI
| Posted: Fri Dec 12, 2008 2:09 am Post subject: |
yes, it is bg 1208/2
art nr: R000898 juin 1995 chassi 51
Is it possible 1080p with only 1080i component 30 feet long and after transcoder RGBHV Port 5 or other port 3
I have now for my dvd player a TVIEW QUAD PRO (focus )connect to port 5 (5 bnc)
what is the best transcoder and what is the résolution
thank you
benareeno
| Posted: Fri Dec 12, 2008 2:45 am Post subject: |
we answered both questions above...
1080i via hdmi with the Moome external with gamma - best
1080i via hdmi with the HDFury + kimcoder with gamma - close second
1080i via hdmi with HDFury - third best
perhaps 1080i via kimcoder with gamma over component is better than above
1080i over component with other component transcoder
jask
| Posted: Fri Dec 12, 2008 4:29 am Post subject: |
the BD55 has Gamma adjustment.
Person99
| Posted: Fri Dec 12, 2008 3:59 pm Post subject: |
| JEAN-HENRI wrote: | yes, it is bg 1208/2
art nr: R000898 juin 1995 chassi 51 |
A BG1208 and a BG1208/2 ARE DIFFERENT MACHINES!!!!! That is why I kept asking. almost no one has a 1208.
You machine WILL NOT do a good 1080p. You need to run at 1080i or 720p.
Person99
| Posted: Fri Dec 12, 2008 4:06 pm Post subject: |
| jask wrote: | | the BD55 has Gamma adjustment. |
Not the kind we talk about on this site that Kim's and others provide.
Person99
| Posted: Fri Dec 12, 2008 4:08 pm Post subject: |
| benareeno wrote: |
Have you actually tested these to see that? I'm curious because HKMod and Kim's customer service far exceeds Moome's so I prefer to use them if it is equal. I know with the original Moome, the HDFury/kimcoder was better, but maybe the new moome is better than HDFury2/kimcoder.
BTW OP, "kimcoder" means Crescendo Systems RTC2200 which is sold on this site.
benareeno
| Posted: Fri Dec 12, 2008 4:58 pm Post subject: |
I haven't personally tested...but Kal has, and I saw screenshots which bear it out. The moome device is superior...but again, not sure if it was being tested against the Fury or the Fury2. But the Fury 2 is expensive and has no gamma control.
Person99
| Posted: Fri Dec 12, 2008 5:28 pm Post subject: |
| benareeno wrote: | | I haven't personally tested...but Kal has, and I saw screenshots which bear it out. The moome device is superior...but again, not sure if it was being tested against the Fury or the Fury2. But the Fury 2 is expensive and has no gamma control. |
Thanks. I'd like to know if it is the Fury2. But, I don't really understand the cost part. The Fury2/GammaX and the Moome full are about the same price. The Fury2/Kim would be a bit more.
I'm betting it was the original Fury, have to ask Kal. I have WAAAAY more confidence in Jean than Moome, so it Jean was involved with the Fury2, I'd place my be on that.
benareeno
| Posted: Fri Dec 12, 2008 6:33 pm Post subject: |
The only transcoder I ever ordered from Moome arrived exactly when he said it would...but I guess others have had far less success.
