1209s quad decoder
SisterOfMercy
Posted: Sat Nov 29, 2008 1:26 am    Post subject: 1209s quad decoder
Hi all,
Would I be able to run my 1209s without the quad decoder that is currently attached to the RGB input and switching board? I'm not planning on using the video inputs, and I also do not need the sh*tty component transcoder. Do I need to connect J401 on the RGB input board to J402 as mentioned in the service manual, or don't I even have to do that?
And by the way; I've been reading the service manual as bedside material, but what function does the video matrix have? The only thing I can find that uses it is the saturation control. Don't know if that works for RGB, or only for video inputs, I never press those buttons.
The kissing and the colour come crashing down
Posted: Sat Nov 29, 2008 2:01 am    Post subject:
I believe the RGB signals run through the quad decoder, the set won't work without it.
SisterOfMercy
Posted: Sat Nov 29, 2008 2:28 am    Post subject:
The RGB signals going to the decoder are present on J401/402. See page 76 of the service manual (page 9 of the quad decoder portion). "Interconnection if decoder omitted", but they don't say anything else.
When looking at the RGB input board schematics the signals are also attached to the output to the RGB driver board. Why the RGB signals would need to go through the quad decoder is beyond me, other than the assumption it has something to do with the saturation controls.
Could I safely try it out by connecting J401 to J402 as stated on that page, or I am I missing something big here?
Posted: Sat Nov 29, 2008 2:36 am    Post subject:
You go right ahead.
As I like to say:
'You can...... I wouldn't'.
I'm all for others modifying and playing. If it blows up, let me know, so I don't try it..Very Happy
Seriously, I don't personally do mods, unless it's beefing up components that are known to fail. I personally won't risk a set failure by pulling out boards that manufacturers designed to be in the set...
Cheers!
Posted: Sat Nov 29, 2008 2:55 am    Post subject: Re: 1209s quad decoder
[quote="SisterOfMercy"]Hi all,
And by the way; I've been reading the service manual as bedside material, but what function does the video matrix have? The only thing I can find that uses it is the saturation control. Don't know if that works for RGB, or only for video inputs, I never press those buttons.[/quote
Why do you wish to remove the quad decoder if you may or may not need it ? Wink
r.bauer
Posted: Sat Nov 29, 2008 11:39 am    Post subject: Re: 1209s quad decoder
The Video Matrix is a circuit that is able to get an RGB signal from a composite or S-video signal.
Saturation only works on Composite and S-video sources as it controls the amount of color signal in the Video Matrix.
WTS
Posted: Sat Nov 29, 2008 4:53 pm    Post subject:
YOu don't need the quad card to use the RGBHV inputs. Unless you plan on using Svideo/composite video get rid of it.
Walter
Ile
Posted: Sat Nov 29, 2008 5:26 pm    Post subject:
That's right, I have removed quad/decoder card long time ago from my 808s and it use same input card what 1209s. In 1208/1209 it wont be as easy, it's needed to cut pc board to half. Laughing
I also removed iris2 camera/card (inside controller) and port3 card for same reason. I don't want any useless crap inside my projector to draw current and cause some problems when they go bad.
SisterOfMercy
Posted: Sat Nov 29, 2008 5:48 pm    Post subject:
Don't you need to solder the diode D105 in place when it is missing?
I kind of need the Iris3, the flashy colours are nice Wink
But, I might remove it in the future, never need it anyway.
WTS
Posted: Sat Nov 29, 2008 6:25 pm    Post subject:
I also removed the iris / the port 3 board and the quad board, this reduces current draw, less heat generated and better air flow with them removed too.
Off hand not sure what diode D105 is, what board is it on?
Walter
SisterOfMercy
Posted: Sat Nov 29, 2008 6:34 pm    Post subject:
D105 is on the back side of the RGB input board. When the quad decoder board is fitted the signals from J401 and J402 only go through an extra diode on the quad decoder board. In the service manual it says that the D105 (on the input board) is only mounted for the RGB version.
The horizontal and vertical sync signals go through this diode, but after looking at the service manual again I think the H and V sync signals go somewhere else and only need to go through that point when using the quad decoder or the line doubler.
If you guys removed the quad board and it worked, then I'm also set. Going to try it out later.
WTS
Posted: Sat Nov 29, 2008 7:09 pm    Post subject:
I see which diode you're asking about, you don't need to worry about that(installing) diode.
Walter
SisterOfMercy
Posted: Sat Nov 29, 2008 9:18 pm    Post subject:
It works, thanks!
For the record; Just remove the quad decoder bord from the RGB input and switch board, and you're done Wink
You really should consider this Curt, as I remember you were looking for a few of those cables. There are four going to every quad decoder board.
Ile
Posted: Sun Nov 30, 2008 7:28 pm    Post subject:
Not so great idea, because then Raster would complain that s-video wont work in his new 808. Laughing
WTS
Posted: Sun Nov 30, 2008 9:31 pm    Post subject:
Oh, forgot about him. I thought we lost him along time ago?
Walter
Posted: Mon Dec 01, 2008 6:48 am    Post subject:
I thought that he need very special quad decoder that can handle progressive S-Video...
DVDO VP-50
New hobby, Rally
