SYC
| Posted: Fri Nov 21, 2008 11:16 pm Post subject: For XG-110, which way to go? 1080P/48Hz, 1080I/72Hz/96Hz? |
I would like to have a judder-free picture, and I have a Lumagen HDP, which can provide 1080P/48Hz, 1080I/72Hz, and 1080i/96Hz.
1080P/48Hz, of course judder-free, but I can see a little flash in bright scene like in commerical theater. But 1080p is a little difficult for an 8" CRT.
1080i/72Hz, I was told that it is best for 8" CRT and have almost 1080p feeling. But I think there should be a frmae with two different fields, so it should not be a correct fresh rate.
My thought is that 1080i/96Hz should be the best solution for XG-100, have anyone tried this before? Will it be judder-free?
SYC
Person99
| Posted: Fri Nov 21, 2008 11:31 pm Post subject: Re: For XG-110, which way to go? 1080P/48Hz, 1080I/72Hz/96Hz |
| SYC wrote: | I would like to have a judder-free picture, and I have a Lumagen HDP, which can provide 1080P/48Hz, 1080I/72Hz, and 1080i/96Hz.
SYC |
You will get a couple of opinions, Mark and I will tell you a 1080i variation, others will say 1080p. But, just so you know, the bandwidth of 1080i/96 and 1080p/48 is EXACTLY the same. 1080i/72 is less.
You will rarely ever see an interlacing artifact due to two different frames being painted even at 1080i/72. The only artifact you will see is some stairstepping on straight lines of around 30 degrees, and scan lines on white content.
Let me ask you this, you've watched 480i/60 your whole life, how many times have you seen interlacing artifacts from two different frames when watching movies? Probably never or rarely. You'll see them even less at 1080i/96.
_________________ Dave
MikeEby
| Posted: Sat Nov 22, 2008 1:13 am Post subject: |
From my experience with different resolutions and refresh rates on an XG 1080p/48 flickers to point of causing a bad headache, I would try 1080i@96Hz. IMO the hot setup with a Lumagen would be try running 1920X817p/60 for scope movies then stretch the image with the scaler to use all 817 lines after that compress back to the correct AR with the projector. I tried this with my HTPC got a great image but the aspect ratio control with a HTPC stinks so I just settled on 1080p/72 but do give up a little sharpness.
A Lumagen has very decent 2:3 pull-down from what I understand so the judder may not be that bad. I was extremely impressed on at 2:3 pull-down on a VP50 at 60Hz when I seen one at Cliff's place, I would think it’s just as good on a HDP. Assuming your doing your own setup, try several different combinations and see what you like. What are you using for HDCP, a Moome or HDFury?
| Posted: Sat Nov 22, 2008 2:00 am Post subject: |
Mike, I get some raster ringing on the LHS edge of my screen at 1080i 96hz (or 1080p 48).
If I move to 1080p 72hz it will get worse.
Does your XG show this effect? I can't try your timings unless I swap out my Oscilliator board, and maybe System board - it's still an XG-75 at heart.
SYC, I tried 1920x802p at 72hz for scope movies, and it didn't look any different to 1080i 96hz. I could still see field lines/scanlines on white objects. I went back to 1080i 96hz. I think this is the best match.
MikeEby
| Posted: Sat Nov 22, 2008 2:05 am Post subject: |
| Mark_A_W wrote: | Mike, I get some raster ringing on the LHS edge of my screen at 1080i 96hz (or 1080p 48).
SYC, I tried 1920x802p at 72hz for scope movies, and it didn't look any different to 1080i 96hz. I could still see field lines/scanlines on white objects. I went back to 1080i 96hz. I think this is the best match. |
Using Kai timings I didn't get any ringing that I recall it was almost a year ago. I just didn't like the 1090i/96 looked but I never really took the time to do a full setup after I got 1080p/72 working.
SYC
| Posted: Sat Nov 22, 2008 2:43 am Post subject: |
Mike, I use Moome without gamma boost. I don't think 817p is a good way to go. It uses the same phosphor area as 1080p 16:9 set-up if we maintain the correct AR. So it is the same the electric guns can not distinguish two lines as Mark mentioned on an 8" CRT. I think I will try 1080i/72 or 96Hz
SYC
SYC
| Posted: Sat Nov 22, 2008 2:44 am Post subject: Re: For XG-110, which way to go? 1080P/48Hz, 1080I/72Hz/96Hz |
| Person99 wrote: | | SYC wrote: | I would like to have a judder-free picture, and I have a Lumagen HDP, which can provide 1080P/48Hz, 1080I/72Hz, and 1080i/96Hz.
SYC |
Let me ask you this, you've watched 480i/60 your whole life, how many times have you seen interlacing artifacts from two different frames when watching movies? Probably never or rarely. You'll see them even less at 1080i/96. |
For CRT, I think it is really hard to see interlacing artifacts
MikeEby
| Posted: Sat Nov 22, 2008 3:09 am Post subject: |
| SYC wrote: | Mike, I use Moome without gamma boost. I don't think 817p is a good way to go. It uses the same phosphor area as 1080p 16:9 set-up if we maintain the correct AR. So it is the same the electric guns can not distinguish two lines as Mark mentioned on an 8" CRT. I think I will try 1080i/72 or 96Hz
SYC |
That is correct phosphor area is the same but the bandwidth requirements are much lower at 817p. For 16:9 you material you would use a different resolution 1080i/72 or 96, I just didn't like seeing the interlace artifacts, and prefer a progressive resolution. It just a matter of personal taste I guess.
| Posted: Sat Nov 22, 2008 3:31 am Post subject: |
I don't see any interlacing artifacts.
I thought I did till I tried 802p and the scanlines were still visible.
Bert Randolph
| Posted: Mon Nov 24, 2008 10:42 am Post subject: |
On my 1351LC I see some noise (squiggely lines) that get less obvious the higher the bandwidth is.
Therfore I use 1080i@120 Hz. Works perfect for me: No squiggeling lines, no flicker, no interlacing artifacts (even windows explorer looks like it was 1080p) and no pulldown artifacts.
Does a Lumagen hdp/hdq do 1080i@120 Hz?
Daniel.
| Posted: Mon Nov 24, 2008 10:56 am Post subject: |
Post your timing Daniel - I'll give it a go.
I just (finally) converted my XG-751 (now) LC chassis to a proper XG-1101LC (except the sticker).
I tried 1080p 72 hz, just to test the higher scanrate, but I need a bazillion porch pixels or the image edges are cropped.
These are Kai's 1080i 96hz, or close to them anyway:
PowerStrip timing parameters:
1920x1080=1920,112,128,115,1080,46,5,30,126655,542
Generic timing details for 1920x1080:
HFP=112 HSW=128 HBP=115 kHz=56 VFP=46 VSW=5 VBP=30 Hz=48
VESA detailed timing:
PClk=126.66 H.Active=1920 H.Blank=355 H.Offset=96 HSW=128 V.Active=1080 V.Blank=81 V.Offset=46 VSW=5
Linux modeline parameters:
"1920x1080" 126.655 1920 2032 2160 2275 1080 1126 1131 1161 interlace -hsync -vsync
Bert Randolph
| Posted: Mon Nov 24, 2008 11:04 am Post subject: |
| Mark_A_W wrote: | Post your timing Daniel - I'll give it a go.
Will do that when I get home.
I guess in Australia the work-day is long over Or is it still sunday??
Daniel
| Posted: Mon Nov 24, 2008 11:10 am Post subject: |
It's 10:10 Monday evening, I'm about to go to bed....tired...been staying up watching the projector until midnight too often...
Bert Randolph
| Posted: Mon Nov 24, 2008 11:21 am Post subject: |
| Mark_A_W wrote: | | ...been staying up watching the projector until midnight too often... |
Always good to find time to actually WATCH something, instead of tweaking the little monster
Bert Randolph
| Posted: Mon Nov 24, 2008 11:23 pm Post subject: |
Okay,
here are my timings for 1080i@120 Hz:
1920x1080=1920,0,48,508,1080,4,10,31,167130,536
HFP=0 HSW=48 HBP=508 kHz=68 VFP=4 VSW=10 VBP=31 Hz=60
PClk=167,13 H.Active=1920 H.Blank=556 H.Offset=-16 HSW=48 V.Active=1080 V.Blank=45 V.Offset=4 VSW=10
"1920x1080" 167,130 1920 1920 1968 2476 1080 1084 1094 1125 interlace +hsync +vsync
MikeEby
| Posted: Mon Nov 24, 2008 11:39 pm Post subject: |
| Bert Randolph wrote: | Okay,
"1920x1080" 167,130 1920 1920 1968 2476 1080 1084 1094 1125 interlace +hsync +vsync |
Very interesting....I might try it myself.
| Posted: Tue Nov 25, 2008 11:55 am Post subject: |
Whoa!! 508 back porch pixels.....that's a lot of bandwidth.
I just tried it, I can't fill my screen. I'm 60mm short either side - I'd have to move the projector or tweak the H-width on the deflection board.
But I'm not getting any raster ringing on the LH side, which means I probably should move my projector back a bit for my 96hz res.
Bert Randolph
| Posted: Tue Nov 25, 2008 12:47 pm Post subject: |
| Mark_A_W wrote: | Whoa!! 508 back porch pixels.....that's a lot of bandwidth.
I was wondering too why there's such a huge back porch...I think I used the arrow-buttons in powerstrip to center the image in my raster and this was the outcome.
I have no problem filling my screen (amplitude is 70ish). Then agein i have not maximized the rasters in order to stay within the wear pattern.
I will try to lower the back porch value, maybe i can further reduce amplitude and save some bandwidth.
Daniel.
