Panayotis Melas
Joined: 24 May 2008 Posts: 13 Location: Kallithea, Greece
| Posted: Tue Nov 18, 2008 6:48 pm Post subject: Peak vs ANSI Lumens |
Can somebody give me an accurate, simple and brief description of the definitions "Peak Lumens" and "ANSI Lumens" and their differences?
For example, when I read that a NEC XG135LC has a brightness of 1100 Peak Lumens, how this number can be expressed in ANSI Lumens?
_________________ Technology helps you live better. Don't live for technology
Person99
| Posted: Tue Nov 18, 2008 7:09 pm Post subject: Re: Peak vs ANSI Lumens |
| Panayotis Melas wrote: | Can somebody give me an accurate, simple and brief description of the definitions "Peak Lumens" and "ANSI Lumens" and their differences?
Thanks |
There is no direct correlation (i.e. no formula). Peak Lumens has no standard of measurement therefore the test can be whatever the manufacturer wants. It is generally what the PJ can put out in a 5%, 10%, or 20% white (100IRE) window (that is, a white box covering 5%, 10%, or 20% of the screen with the rest being black). It is generally measured in "fry the tubes" mode.
ANSI lumens has a standards based way of measuring which is defined in IT7.215 has a very precise measuring technique which measures the real peak output on a full white field.
For details, read this: http://en.wikipedia.org/wiki/Lumen_(unit)#ANSI_lumens
Basically, the current draw on a CRT is WAAAAY to much on a full white field, so the current must be seriously limited typically cutting the lumen output on a full white field to less than 20% of the "peak" number.
_________________ Dave
| Posted: Tue Nov 18, 2008 7:11 pm Post subject: |
ANSI lumens are measured using an ANSI-standard method for adjusting the projector so that you can distinguish between 90, 95, and 100% white, then displaying a full-white field and measuring brightness.
Peak lumens are measured with a small window in the center of the screen - usually 10 or 20 percent of the image area.
So, there isn't a way to "express" peak lumens as ANSI lumens or vice-versa because they're different - at least with a CRT. A CRT projector, because of the nature of the device, can display a much brighter white in a small are than it can in a larger area. OTOH, a digital projector will display the same amount of white regardless of how much white is displayed.
A typical 8" CRT like an XG or G70 might measure 1100 peak lumens (in a 20% window), will probably only measure only 200 lumens displaying a full-white field (ANSI lumens).
On low-APL content like a space scene or a night scene, CRT looks awesome. On high-APL content like a snowy scene on a sunny day (Happy Feet, Ice Age, Fargo, etc.), that's where CRT falls short. Whites aren't bright white, but are instead a dingy or grayish white.
| Posted: Tue Nov 18, 2008 7:16 pm Post subject: |
Baaah! You beat me, Dave!!!
I always wondered... Why couldn't the projector manufacturers just build bigger HVPS's so current draw wouldn't have to be quite so severely limited? I'm sure there were some design limitations (size, cost, heat?), but why couldn't they have gotten to a 3:1 or even 4:1 relationship (window:full-field) instead of 6:1 Or, is it the tubes themselves that can't be driven that hard?
Person99
| Posted: Tue Nov 18, 2008 7:19 pm Post subject: |
| ecrabb wrote: | | On low-APL content like a space scene or a night scene, CRT looks awesome. On high-APL content like a snowy scene on a sunny day (Happy Feet, Ice Age, Fargo, etc.), that's where CRT falls short. Whites aren't bright white, but are instead a dingy or grayish white. |
For those that don't know: APL=Average Picture Level, which effectively averages the grayscale value of the entire frame.
On a high APL scenes, I agree that ANSI CR is a good indicator of brightness and how good those bright scenes will look.
However, it is not a CRT's peak lumens IMO that makes low APL scenes look good. It is a low black level coupled with a decent on/off. I could have a 2000 ANSI lumen projector, but if black was .1 ftL, low APL scenes are going to looked washed out--just like they do on my current PJ.
Person99
| Posted: Tue Nov 18, 2008 7:21 pm Post subject: |
| ecrabb wrote: | Baaah! You beat me, Dave!!!
SC |
Maybe if a CRT did 1200 Lumens on a full white field it would create a black hole.
Person99
| Posted: Tue Nov 18, 2008 7:23 pm Post subject: |
| ecrabb wrote: | | Baaah! You beat me, Dave!!! |
Yes, and I provide helpful links.
| Posted: Tue Nov 18, 2008 9:33 pm Post subject: |
Dave, oops - miscommunication on my part. I didn't mean to imply that CRT looked great with low-APL material because of the low light output.
Instead of saying "CRT looks awesome with a space or night scene" and leaving it, I should have said that the good peak light output COMBINED with low black levels makes those scenes look great. For instance, it's the night or space scenes where CRT's really shine. The CRT's peak output can make those stars damn bright, while displaying them against the CRT's inky black background. That's the very definition of high contrast.
Of course, things start getting iffy for the CRT in higher-APL scenes where ANSI contrast gets pretty poor. Then, things go south further with very high-APL scenes where you have both poor ANSI contrast AND low ANSI light output. A smallish black car in a brightly-lit snowy scene is a worst-case scenario for CRT. You'll have both elevated black levels on the car and dingy whites on the snow.
OTOH, a digital shines in the black car/bright snowy scene (or Ice Age, Happy Feet, etc.) and sucks a little on the space and night scenes.
Sorry for the confusion.
Person99
| Posted: Tue Nov 18, 2008 10:37 pm Post subject: |
| ecrabb wrote: | | Dave, oops - miscommunication on my part. I didn't mean to imply that CRT looked great with low-APL material because of the low light output. |
No, I interpreted it to mean you were saying that they looked great because of the high peak output. I was just pointing out that peak output. I was just pointing out that it is not peak output alone, but low black level. Moreover just for clarification because I know you know what you are talking about.
| ecrabb wrote: | | For instance, it's the night or space scenes where CRT's really shine. The CRT's peak output can make those stars damn bright, while displaying them against the CRT's inky black background. That's the very definition of high contrast. |
Unless there are too many bright stars or a "largish" bright object, then the CRTs poor ANSI CR will come into play and brighten up space a little too much.
| ecrabb wrote: | | OTOH, a digital shines in the black car/bright snowy scene (or Ice Age, Happy Feet, etc.) and sucks a little on the space and night scenes. |
As a generality I'd agree, however that is rapidly changing. The RS2 has a very high native CR so it looks good on both the scenes a CRT looks good on and the scenes a digital looks good on. Its weak point is a few scenes where high ANSI would give it punch (not the black car on snow as the snow is so white, the car will look black no matter how gray it is).
Also, good dynamic irises work fairly well. If the PJ has a native on/off of around 3000:1, then your space scene can be pretty black and even though the stars won't be as bright as the CRT's stars they will be enough different to look almost as good. Further, the white snow will be very bright and white and even though the black car is dark gray, thanks to the human visual system, it will look black.
So, while the digital generalizations are certainly true for all 720p projectors, they have become less true for many of the digital 1080p PJs.
tony359
| Posted: Mon Nov 24, 2008 5:54 pm Post subject: |
Can someone give me some impression on brightness between Sony 1271 and NEC XG135LC? Peak is 650 vs. 1200 but full screen is 200 vs 230. Would be really brighter an XG135LC than a 1271?
Ciao
Antonio.
| Posted: Mon Nov 24, 2008 8:26 pm Post subject: |
XG is subjectively almost twice as bright as a 1271.
| Posted: Mon Nov 24, 2008 8:40 pm Post subject: |
Hmm.. I don't know about that, Mark... I don't know if "twice as bright" is how I'd characterize the difference. In going from a 1271 to a G70, I can't say it seemed like brightness doubled. I wish I would have been able to measure brightness on the 1271 before I sold it, but I do know my G70 is doing ~12fl in a 10% window. That means the 1271 would have only been doing about 6 - which I'd find hard to believe - because it would have been almost unwatchable. I'd guess more like 9 or 10.
I think the peak numbers on the newer machines are in "fry the tubes" mode - which very few of us actually use.
If I were just going to give a "seat-of-the-pants" impression without actually measuring, I'd say the 1271 is more like 70-80% of the brightness of the G70 (or XG) - when you have both machines set up as you'd actually use them.
I'd say the 200 vs. 230 full-white spec is closer to the real difference between the two machines on typical high-APL material. Of course, there's a massive difference between in the two in terms of sharpness and contrast.
| Posted: Mon Nov 24, 2008 8:53 pm Post subject: |
I went from a 1251 to a PG Xtra to a XG LC.
The 1251 was half as bright as the Xtra. Ok, three quarters maybe, but it was DIM.
A 1251/71/52/72 is just not worth playing with these days.
| Posted: Mon Nov 24, 2008 9:13 pm Post subject: |
To be fair, I did have a very nice 1271. Not mint by any means, but only ~2500 hours and pristine tubes. Did yours have a lot of hours on it? I never felt my 1271 was "dim" at all.
I don't know if I'd say "not worth playing with", either. I mean, they're only $200-300. Digital projectors in that price range are crap, so a 12xx, assuming it's in decent condition, could make a hell of a projector for somebody on a tight budget. XG's and G70's are still around a grand, so there's a lot of road between the two for a beginner or somebody on a budget.
If you can afford a nicer machine like a G70 or XG, then by all means...
tony359
| Posted: Mon Nov 24, 2008 11:51 pm Post subject: |
I don't think that FL are a linear unit measure and probably the "half brightness" figure is when your image is 3-4FL below.
Thanks for your opinions guy. I was watching an XG135LC but seems that if I want it I must take it "as is" without even try it!! I don't think I'll take it...
Ciao
Antonio
| Posted: Tue Nov 25, 2008 6:05 am Post subject: |
My 1251 was about 2000 hours I think. Hint of wear on the blue tube face.
It wasn't very bright.
My XG was $500
Antonio, is it the same XG as the one you saw? Is it expensive? I would leap at an XG135LC over a 1271.
tony359
| Posted: Tue Nov 25, 2008 10:56 am Post subject: |
The one I saw?
I mean that the buyer cannot tell me by phone the condition of the item and his condition is that I must go there, take the XG "as is" with no chance to try it even for a moment. 1350$
Ciao
A
| Posted: Tue Nov 25, 2008 11:02 am Post subject: |
So it's not the same XG as the one said you watched? Or did you mean you were watching the Auction? I misunderstood.
In that case offer him $200.
That's a scam in the making. Without information on the Tubes, it's just a chassis, possibly broken.
I wouldn't buy that either.
Ciao
Marco
