Using a HDFury2 with a Sony G90
RickSaada
Posted: Thu Nov 13, 2008 5:38 am    Post subject: Using a HDFury2 with a Sony G90
The folks in the fury forum suggested I check with the G90 experts over here:
Anyone get the fury2 to work with the G90? I just got mine, and I’ve got lots of problems, both with using laptop HDMI output and PS3 output. If I use the HDFury in RGB mode I get a pretty nice image with my laptop background screen. As soon as I put white on the screen though (say IE or Notepad) and drag it around I start getting big regions of gray. If I maximize it the screen goes almost black. This happens at both 1080i and 1080p.
So I tried using the other mode on the fury instead, swapping the G90 to expect that format, and I got large vertical black bands (about a foot wide on my 8’ screen) near but not at the left side. With the PS3 I had similar issues. The screen would occasionally look OK (but not great) but when I tossed in Planet Earth on BluRay the display would dim or fade. In all cases I’ve got the power supply plugged into the HD-Fury2 and I’m running a 6’ cable to the monitor (straight up) for test purposes. Anyone got some magic they've used with the G90 to make this work? Or did I get a bad Fury unit?
Thanks for any advice.
Rick
Posted: Thu Nov 13, 2008 5:39 am    Post subject:
Have you tried swaping cables?
RickSaada
Posted: Thu Nov 13, 2008 5:43 am    Post subject:
Nope, but I will. I'll have to grab another HDMI to test with.
Chuchuf
Posted: Thu Nov 13, 2008 1:35 pm    Post subject:
You might need to go into the G90 service menu "Input Setting" with the fury installed and set the "Clamp" to HP or H/C from auto. This should straighten out the picture if it is varying in brightness and getting weird bands of dark as scenes change.
Terry
Posted: Thu Nov 13, 2008 2:39 pm    Post subject:
Terry
dito.
RickSaada
Posted: Thu Nov 13, 2008 7:50 pm    Post subject:
Setting the clamp seems to have fixed it, at least with my laptop as input. I'll try and drive it from a PS3 this weekend to see what bluray looks like. Thanks for the help!
Rick
HaydnG90
Posted: Thu Nov 13, 2008 8:07 pm    Post subject:
Don't feel that you're alone. I think most of us have been caught out at one time by this idiosyncracy of the G90. Thank goodness for sites like this. Thumbs Up
