BG 808S not turning on
Trunks81
Posted: Sun Nov 02, 2008 4:27 pm    Post subject: BG 808S not turning on
Hello
I have an problem with my barco , It whas very strange the barco turned its self on a couple of times.
And at first i could switch it off with the remote i have, The one on the barco doesnt respond.
Now both remotes are not working.
So now i opend the barco and see the next led burning.
-Standby
-PWR cycles
-Error
-RCU
What does this mean ? and can it be fixed easy ? Dont want to miss my barco.
Greetings Trunks81
Posted: Sun Nov 02, 2008 4:53 pm    Post subject:
Chances are the power supply (SMPS) is bad. I can repair that for you.
Trunks81
Posted: Sun Nov 02, 2008 5:29 pm    Post subject:
Hello Curt
I already checked the fuses on the SMPS they al seem oke.
The solder point looks fine !
Also checked the fuses on G2/diagnostic board none of the diag led are burning.
And checked the AC input board fuses are oke also, En EHT the fuses is oke
The red led on the EHT board isnt burning !
What will an new SMPS Board cost ? or the cost for repair ?
Greetings Trunks
Posted: Sun Nov 02, 2008 5:55 pm    Post subject:
OK, re-reading, it could also be your controller board. That's rare, but possible. I'd send both of them in, as the controller boards are specific to the set. Post your city and country in your profile, but by your writing it sounds like you're in Europe. Testing/repairing and return shipping will be about $300 USD for the two boards. No charge to test a board if it checks OK, only the extra $25 for shipping it back.
Try this first though: On the wired keypad, there's a recessed button that is unmarked. Press that, then press '0,0,0' on the keypad. That will reset the CPU/controller board, and _might_ bring it back to life, but chances are that won't do anything. I still think the SMPS has failed, but such that the fuses are not blown.
Trunks81
Posted: Sun Nov 02, 2008 6:19 pm    Post subject:
Oke Tried that but no change !
Trunks81
Posted: Sun Nov 02, 2008 7:14 pm    Post subject:
Oke i have tried some things if i pull out the Convergence board
The Barco goes on agian and dont see any Error leds any more
Greetings Trunks
Cousin.It
Posted: Sun Nov 02, 2008 8:34 pm    Post subject:
On the front of the convergence board there is a small circuit board with the two RS 232 connectors on it that come out to the front of the projector. Inside there is a small yellow cable with about 9 wires connected. You can try disconnecting that connector and see if it will power up with the convergence board installed again.
Based on some of what you've said, I would also check that there are no buttons on the built-in or external remote controls as the Barco's have the problem of them sticking down in the hole.
Mark
Trunks81
Posted: Sun Nov 02, 2008 8:42 pm    Post subject:
Hello
I have done what you said pulled out the 9 wire cable ! the one that is going to the Ir and RS232
Inserted the convergence board again and now the barco starts agian !
What does this mean ? Which part is causing the Error now ?
Greetings Trunks
Cousin.It
Posted: Sun Nov 02, 2008 8:48 pm    Post subject:
You said you were having RCU and Error lights and the remote control talks through the front side of the projector here. There's another IR port on the back of the projector too. Put a piece of tape or piece of paper over the IR hole on the front of the projector to block external signals, hook the little board back up, and try again.
Might be something in your room irritating that front IR receiver like a flourescent light.
Mark
Trunks81
Posted: Sun Nov 02, 2008 8:54 pm    Post subject:
Hello
Ive put back agian that cable and put some tape on the IR Receiver and now it starting up lite it should
Thank you for you time and i hope that this is all
I also found the problem maker .... Its my new Philips 47PFL9603 Tv when i put it out the problem is solved
Greetings Trunks
Cousin.It
Posted: Sun Nov 02, 2008 9:01 pm    Post subject:
It still seems that you must have something in the room that is sending out a signal that is interfering with the front IR port. You should see what electrical, electronic, lighting, etc. sources are turned on next to your projector. Personally, I wouldn't want to lose the use of the front IR port since I still point my remote at the screen and bounce it back to the projector.
Edit - Oops, just saw your comment about the new TV.
Mark
Trunks81
Posted: Sun Nov 02, 2008 9:08 pm    Post subject:
Want to thank you for your help.
But in the mean time where can i find documents about how to make the SMPS better agian so that wont be the part that is going defective.
