Superbit1978
| Posted: Mon Oct 27, 2008 11:58 am Post subject: Quick help |
Hello people on this great forum.i have a Question i own a barco 800GA and i want two buy a HD FURY OR Moome box wich one do yours truly recommend.i want easy instal because i don,t own a HTPC just 2 dvd players HD-DVD and BLU-RAY so thanks and regards
jkruger
| Posted: Mon Oct 27, 2008 1:23 pm Post subject: |
Sounds like you need an HDMI switcher and the HDFury2.
Superbit1978
| Posted: Mon Oct 27, 2008 1:30 pm Post subject: |
Hello so y need both of them or can i just get one. or i was thinking about only a component to RGBHV converter may this help.and what is the sweet spot of a barco 800G.wich resolution is good for the barco 720p 1080i 1080p
regards patrick
jantje112
| Posted: Mon Oct 27, 2008 3:35 pm Post subject: |
Just buy the old hdfury (cheap) and a hdmi switch. That way you can use both devices without cable unplugging etc.
| Posted: Mon Oct 27, 2008 4:29 pm Post subject: |
| jantje112 wrote: | | Just buy the old hdfury (cheap) and a hdmi switch. That way you can use both devices without cable unplugging etc. |
I agree, for a B800 the old fury is just fine. No pint in putting a $350. moome box on a $400. PJ.
Superbit1978
| Posted: Mon Oct 27, 2008 6:20 pm Post subject: |
Oke thanks and what is the best resolution for the barco800g 720p or 1080i
regards patrick
jkruger
| Posted: Mon Oct 27, 2008 6:26 pm Post subject: |
Try both and see what you like. I think it will do 1080i well enough.
Person99
| Posted: Mon Oct 27, 2008 6:38 pm Post subject: |
| Superbit1978 wrote: | Oke thanks and what is the best resolution for the barco800g 720p or 1080i
regards patrick |
1080i.
Honesly, I would not invest too much into this PJ at this point. You could get a used digi PJ with a digital input for about $600 that would look better than the 800. You could also step up to an EM machine for not that much these days.
Although not a popular sentiment you really should think hard and look around. The 800 was a great machine when it went for $1700 compared to the best of the 720p digitals at $12,000. But now, those digis are <$1000. YMMV
_________________ Dave
| Posted: Mon Oct 27, 2008 7:03 pm Post subject: |
| Person99 wrote: | | Honesly, I would not invest too much into this PJ at this point. You could get a used digi PJ with a digital input for about $600 that would look better than the 800. You could also step up to an EM machine for not that much these days. | true but an HD fury and HDMI switcher will work on any CRT, which is not the same as"investing in a Barco 800". That $600. digital PJ will quickly double or triple in cost once you start replacing bulbs.
jkruger
| Posted: Mon Oct 27, 2008 7:13 pm Post subject: |
Who wants to watch a digital anyway? The switcher and fury will work with a LOT of other stuff too.
| Posted: Mon Oct 27, 2008 9:58 pm Post subject: |
| jkruger wrote: | | Who wants to watch a digital anyway? The switcher and fury will work with a LOT of other stuff too. | Dave's one of "them" now and a $600. DLP is all of a sudden OK.
jkruger
| Posted: Tue Oct 28, 2008 1:26 am Post subject: |
Ah... Didn't realize we lost him.
Superbit1978
| Posted: Sat Nov 01, 2008 4:21 pm Post subject: |
Hello guys yeah i had a couple Digital projectors Marantz vp-s3 and the sony vpl-12 i think.but i like more the film like image from CRT plus the black level is good and that for an old Barco i want to set up this barco first because i don,t have a lot of knowledge about CRT projectors .so eventely i would make the jump to a EM if they can give me a good price and that means a good price because i don,t want to sell my Kidneys o well maybe for a BARCO REALTY 909 or SONY G90
regards patrick
Superbit1978
| Posted: Sat Nov 01, 2008 5:16 pm Post subject: |
Oke Gentleman i am now at RASTER SETUP you need to adjust the raster that it gets right in the middle.how do you get THE RASTER SMALLER because when i move left to right and up and down.it looks like it stays more on the left side
thanks patrick
| Posted: Sat Nov 01, 2008 8:57 pm Post subject: |
| Superbit1978 wrote: | | Oke Gentleman i am now at RASTER SETUP you need to adjust the raster that it gets right in the middle.how do you get THE RASTER SMALLER because when i move left to right and up and down.it looks like it stays more on the left side thanks patrick | you don't want to shrink the raster, use as much tube face as possible. Also, don't confuse centering of the raster, which is usually set with and internal test pattern grid, with centering the image inside the raster. They are independant of eadh other. Center raster first then center image. The second adjustment is called Phase control, not sure what Barco calls it though?
Superbit1978
| Posted: Sun Nov 02, 2008 9:29 am Post subject: |
oke will check it out now.so i need to use as much tube face as possible.i deleted all the memory block in there started from scratch i did get a decent image and that for a noob.more later
thanks patrick
Superbit1978
| Posted: Sun Nov 02, 2008 1:54 pm Post subject: |
Hello i now that i ask this before.but i want to be sure i want to order a HD-FURY but wich one of the 2 here is what i am looking at oke i am gone use it on the barco g800 for now but in the future i would like to buy a better CRT projector so that it would come in handy for later.Because sombody sad that it,s not worth to spend more money on the BARCO 800G he recommended to buy the HD-FURY 1 so any help would be nice
thanks patrick
