Arno P
Joined: 01 Jan 2007 Posts: 282 Location: The Netherlands
| Posted: Sat Oct 11, 2008 6:51 pm Post subject: Marquee 9500 split screen |
Well, after the big clean up of new red C and glycol I did a reset on the pj to start from scratch...
With the internal pattern erverything was fine...convergence etc went well...
Switching to the htpc moome 1080p resulted in a split screen with the lowest part of the screen projected on the top half and the highest part of the screen projected on the lowest half...
Was thinking of a sync issue or something...
Anybody got a clue?
_________________ "Obviously you're not a golfer"
| Posted: Sat Oct 11, 2008 7:03 pm Post subject: |
Hello
Sync or a control board issue. Have you tried other sources?
Arno P
| Posted: Sat Oct 11, 2008 7:07 pm Post subject: |
| Tim in Phoenix wrote: | Hello
Nope
Arno P
| Posted: Sat Oct 11, 2008 7:11 pm Post subject: |
| Nashou66 wrote: | Also try adjusting the timings in the HTPC and use a grid from an external source, the internal and external timings and syncs can be very different. But first do as Tim says and try another source tot he Moome. if ti si better with that then you have to go into the HTPC timings and play around
Athanasios |
Going to tweak pstrip a bit
Arno P
| Posted: Sat Oct 11, 2008 7:16 pm Post subject: |
| Nashou66 wrote: | TSE told me Marquees do not like short sync timings so make then a bit longer and see what happens.
Athanasios |
Ok thanks
jantje112
| Posted: Sun Oct 12, 2008 7:42 am Post subject: |
Probably yes, but did you check the v-phase setting?
Arno P
| Posted: Sun Oct 12, 2008 12:43 pm Post subject: |
| jantje112 wrote: | | Probably yes, but did you check the v-phase setting? |
Got it...
A balance of pstrip timing and V-phase
