Marquee Neck Boards
Ohmess
Posted: Sun Sep 28, 2008 2:35 am    Post subject: Marquee Neck Boards
I just bought a set of 9500 tubes with the mounting hardware, magnetics, lenses and neck boards. I am thinking about modifying the neck boards, but would like to make sure they work before I do so.
Does anyone know if Marquee neck boards are backwards compatible? Can I use my 8500 to test my 9500 neck boards?
Posted: Sun Sep 28, 2008 2:45 am    Post subject:
yes they are, you might have to cut a bit of the pcb or the tube socket to make them fit if they are the type that has a little extra where the socket
plugs in.
jantje112
Posted: Sun Sep 28, 2008 7:40 am    Post subject:
Make shure the 9500 tubes are the original and not LUG versions
Ohmess
Posted: Sun Sep 28, 2008 2:44 pm    Post subject: More please
How can I make this determination?
Ohmess
Posted: Sun Sep 28, 2008 11:16 pm    Post subject: Thought
They are Panasonic P19 LCPs, which I presume are not LUGs, correct?
Posted: Mon Sep 29, 2008 2:47 am    Post subject: Re: Thought
Correct.
