| Posted: Sat Sep 27, 2008 11:47 pm Post subject: Belly fans |
I really have to replace the 120mm belly fans in my 4600HD. One of them is getting loud. Have we settled on a decent, reliable and quiet fan for this purpose? I'm also considering changing the mounting method as the originals are bolted directly to the case. I've seen foam and rubber isolator mounts. Has anyone used these? Space is not a issue.
_________________ Chip
| Posted: Sun Sep 28, 2008 1:23 am Post subject: |
try to find a fan with the highest cfm, with the lowest RPM, and a very important thing many dont look at is the pressure they produce measured in H20, i think its the amount it deflects water, not sure what distance they use from fan to water but my assumption could be wrong, i used the thermaltake silent cat fans form Directron. I had to add a resistor to my 12 volt step down power supply i built to slow it down some more i think i had it at 9 volts for a nice flow. http://www.directron.com/a2329.html
Also if you want to test how much air flow you existing fan has and want your new fan to match Find a spot where to fan blows up out of the case and tape a piece of paper on one side so it falls over that outlet of air, turn on the fan and measure the papers deflection, Try to get you new fan to match that deflection as it will be the same airflow.
Heywood Jablome
| Posted: Sun Sep 28, 2008 5:41 pm Post subject: |
I've got some nice high density foam to put the belly fans on.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
snkby
| Posted: Sun Sep 28, 2008 7:21 pm Post subject: ive been looking at the enermax fans with |
the magnetic bearings.
120mm states 19db for 44cfm if i remember right.
i want to get the 92mm version for my psu but they are available only overseas and would be way too much $$ to geth them here.
anyone have any experience with the enermax magnetic bearing fans ?
jkruger
| Posted: Sun Sep 28, 2008 8:10 pm Post subject: |
i'm using the ENERMAX MARATHON UC-12EB ENLOBAL BEARING FAN, 17dBA, 44cfm... can't hear em. Mounted them with the little rubber isolation mounts. Had to have a buddy build a little starter circuit for me, the Barco start voltage is too low to start them every time, but once they are going they work just fine.
snkby
| Posted: Sun Sep 28, 2008 9:42 pm Post subject: |
sweet!!
thats what i wanted to hear!
or actually -not- hear! lolololol
what pj did you mount them in?
i measured the opening of the marquee8000 and its just at 120mm so im thinking i might have to shave the fan casing.
jkruger
| Posted: Sun Sep 28, 2008 9:53 pm Post subject: |
120mm is standard size for the barco 1209s. I also removed the rear mounted remote control for increased airflow, (opens up a large hole in the exhaust area of the case) And I'm leaving the outer cover off during the summer months because it is in a loft over the garage that has little insulation and gets quite hot up there even without the pj running.
| Posted: Sun Sep 28, 2008 11:01 pm Post subject: |
| Heywood Jablome wrote: | | I've got some nice high density foam to put the belly fans on. |
You might want to cut up some mouse pads, they were my choice for Marquees.
jkruger
| Posted: Sun Sep 28, 2008 11:23 pm Post subject: |
If they were bolted directly to the chassis you might find the rubber isolators very easy and very quiet. It really doesn't take much rubber isolation to reduce the vibration noise dramatically. The Enlobal fans have virtually zero mechanical noise so the airflow is the only thing you hear.
| Posted: Mon Sep 29, 2008 2:46 am Post subject: |
| jkruger wrote: | | If they were bolted directly to the chassis you might find the rubber isolators very easy and very quiet. It really doesn't take much rubber isolation to reduce the vibration noise dramatically. The Enlobal fans have virtually zero mechanical noise so the airflow is the only thing you hear. |
i use those in the Marquees LVPS with the rubber iso mounts, love those fans! wish they had more air flow for the Belly fans tho, I think the Marquee belly fans have to be 56 cfm unless you mod it to 4 fans.
snkby
| Posted: Mon Sep 29, 2008 3:59 am Post subject: |
so what would a 4-fan mod look like ?
on the lvps there seems to be enough room only for 2 fans.
i was going to mount the 120mm fans on a thick piece of foam that would funnel down between the fans and the lvps chassis to channel the air into the lvps.
im also going to use the 120mm fans for intake and exhaust in a hushbox/coffeetable for another marquee8000.
| Posted: Mon Sep 29, 2008 1:02 pm Post subject: |
| snkby wrote: | so what would a 4-fan mod look like ?
im also going to use the 120mm fans for intake and exhaust in a hushbox/coffeetable for another marquee8000. |
For the LVPS i used 2 120 mm enermax fans, i had to shave them down to fit in the chamber. Make sure they will sloide intot he chamber first before you mount them to your LVPS. On the Belly fans you need to cut the fan tray to allow one more fan.
Ohmess
| Posted: Mon Sep 29, 2008 3:55 pm Post subject: |
I cut the fan tray as Nashou66 suggests, and mounted 4 SilenX 120 mm 14 dBA 58 cfm fans. Even though were out of production, I got them directly from SilenX in December of last year.
| Posted: Mon Sep 29, 2008 4:04 pm Post subject: |
| Ohmess wrote: | | I cut the fan tray as Nashou66 suggests, and mounted 4 SilenX 120 mm 14 dBA 58 cfm fans. Even though were out of production, I got them directly from SilenX in December of last year. |
Can you explain how you wired them to take into account the voltage drop you need 24-->12 volts. If you wired them in series to lower the voltage you have to be carefull as if one fails they could all stop.
Ohmess
| Posted: Mon Sep 29, 2008 5:01 pm Post subject: Yup. |
I wired them in series, and I hope to hell they don't fail. I had thought about trying to wire in a warning light, but didn't get around to it. The fans are brand new; so I'm hoping they have a long life.
I can hear them if I have nothing else on in the room.
snkby
| Posted: Tue Sep 30, 2008 3:14 am Post subject: |
so how do you even get to the belly fans ?
im thinking the pj has to be flipped over ?
i can see them through the side grill but cant see how to get at them.
thanks.
| Posted: Tue Sep 30, 2008 3:26 am Post subject: |
I took the whole PJ apart when i did the HD 144 mod. While it was apart i cleaned it out really well, lined the bays with acoustic foam and dynamat, rerouted the cabling and cleaned all contacts especially grounds. The fans are under the tubes, easiest way to get them out and see how the cooling system works. Its all integral, the belly fans pull air from the side grills and pushes air up into the plastic tube covers down the neck to the neck boards and then out the back and around the back case cover over the rear heat sink. they also push air up through the FCM and HDM, this is where i measure the deflection of paper to find out the pressure it creates.
Ohmess
| Posted: Thu Oct 02, 2008 11:23 am Post subject: |
Hey Nashou66, can you post more information on the step down power supply you built?
