9500 Horizontal convergence jumps
Arno P
Posted: Sat Sep 27, 2008 8:17 pm    Post subject: 9500 Horizontal convergence jumps
When adjusting the horizontal convergence sometimes it happens that there is a relatively large vertical line jump to another horizontal position. After that the horizontal convergence can be adjusted as normal. Is this one of the things that can be solved with a mod?
Is this the so-called "Snap-Problem" or is it something else?
"Obviously you're not a golfer"
Posted: Sat Sep 27, 2008 10:41 pm    Post subject:
sounds like it. I think Paul b. did the mod in my marquee thread, check it out.
Elaine Benes
Posted: Sun Sep 28, 2008 12:50 am    Post subject:
Indeed I did do a mod to try and fix the "snap" problem in one of my projectors, but it failed to remedy the problem, I needed to replace my VDM with a modded one. Actually, I only had a modded one available to me, I didn't specifically replace it with a modded one "on purpose" to fix the issue...
Now that it isn't snapping any more, its a very stable running machine.
Posted: Sun Sep 28, 2008 2:01 am    Post subject:
The Snap fix is to the CLM here is pauls pics ,scroll down a bit :
https://www.curtpalme.com/forum_archived/viewtopic.php@t=9608.html
Arno P
Posted: Sun Sep 28, 2008 6:16 am    Post subject:
Thanks guys Wink
