VGA - BNC Cable does not work
PhoneTech
Posted: Fri Sep 19, 2008 12:08 pm    Post subject: VGA - BNC Cable does not work
I recently bought a new VGA - BNC cable. High Quality and very short 30cm:
Specs:
The Extron SYM BNCM Series cable assemblies utilize Extron MHR-5 Cable terminated with five, color-coded male BNC connectors on one end and a 15-pin HD male connector on the other. The SYM BNCM Series cable assemblies are ideal for connecting a computer-video source to a projector or other display device.
Features
* High performance cable designed for transmission of computer-video
* Utilizes Extron MHR-5 Cable
* Smaller diameter, more flexible, and easier to pull than regular coax cable, improving ease of installation
* NEC CL2 rated, non-plenum cable
* Terminated with five high quality 75 ohm BNC male connectors at one end
* Terminated with a high quality molded VGA male connector at the other end
* VGA shell grounded for ESD electrostatic discharge protection
* Injection mold with overall foil shield for improved EMI electromagnetic interference isolation
But when I connect this cable to my moome box and my projector I get no image. I do get an image when connecting my old 1.8m cable.
I already switched the HV sync, but this didn't help.
When using a multimeter to check the pinout fo the cable I get identical results between de old 1.8m one and the new 30cm cable.
Is there something I am missing? The cable is supposed to be terminated with 75Ohm connectors. Is there anyway to check this?
Bart
blue_z
Posted: Sat Sep 20, 2008 7:53 am    Post subject: Re: VGA - BNC Cable does not work
Hi there
For each of the five BNC connectors, did you test both the center conductor and the outer barrel for continuity to a HD-15 pin?
And then test for no continuity between any two centers?
And then test for no continuity between any center and ground (outer barrel)?
Regards
PhoneTech
Posted: Mon Sep 22, 2008 3:19 pm    Post subject: Re: VGA - BNC Cable does not work
blue_z wrote:
Hi there
Regards
I only tested the inner en outer BNC connection to the HD-15 pins. Haven't checked continuity between the 2 centers. Can I check if the cable is 75Ohm?
Regards,
Bart
beun
Posted: Mon Sep 22, 2008 4:02 pm    Post subject:
Probably not with the equipment you have but except for very long runs it will not make a difference.
Kim
ESL-0.5 Full Range Electrostatic Loudspeakers | RTC2200 Component to VGA Converter with Gamma Boost
