nebulous
| Posted: Thu Sep 18, 2008 12:57 am Post subject: Horizontal lines over video on Barco 701s. Videos attached. |
Thanks to help from this forum my Barcodata 701s is up and running again. Unfortunately the saga continues. Video converges decently after a little tweaking, but has some anomalies. Dark lines cover the video depending on what is being displayed at the time. Since I don't have the ability to articulate what I mean I'll demonstrate directly.
Here are two videos of what I mean. The first is of the screen, the second of the tubes. I didn't see this one in the troubleshooting section so I thought one of you all may have some insight.
http://www.crashed.net/~nebulous/barco/screen.avi
http://www.crashed.net/~nebulous/barco/tubes.avi
Any suggestions appreciated as always.
| Posted: Thu Sep 18, 2008 1:50 am Post subject: |
That could be it. It could also be the H phase control is set off too much. That's in the geometry menu at the top.
nebulous
| Posted: Thu Sep 18, 2008 2:19 pm Post subject: |
Well its certainly not a scanrate that the proj can't handle. Its plain old prog scan dvd 31.x kHz. Interestingly enough when I tried block 5 rather than 6 the problem disappeared, so you're probably right that there was some problem with the geometry. I'll try copying block 5 to block 6 and see if it works on both to eliminate a variable. Slightly OT, Curt, are 701 convergence boards part of the recent board sale?
| Posted: Thu Sep 18, 2008 3:15 pm Post subject: |
Yes, but so far the two sets I've parted out had bad convergence boards..
I've got 2 more to look at today, I'm sure they will be OK.
