Barco 1209 loss of picture
justin13
Posted: Mon Sep 08, 2008 7:47 pm    Post subject: Barco 1209 loss of picture
I could use some help troubleshooting this one-
I have a Barco 1209 that, after about an hour and a half of use this afternoon, stopped projecting a picture. I cycled the power on the projector, and that restored the picture, but it switched off again after a minute or two of use. What could be causing this?
Posted: Mon Sep 08, 2008 7:52 pm    Post subject:
Check the red light on the EHT board. CHances are the HV is shutting down. Bad EHT board, quadrupler or splitter if that's the case.
justin13
Posted: Mon Sep 08, 2008 8:27 pm    Post subject:
When I lose the picture, the red LED comes on- that's a fault indicator, correct?
Posted: Mon Sep 08, 2008 8:54 pm    Post subject:
Correct. If you have no spares, then send me your EHT board and quad, and I'll test them here. It can be the splitter as well, but that requires unsoldering.
justin13
Posted: Mon Sep 08, 2008 9:00 pm    Post subject:
I swapped out the EHT, and it seems to have been the solution. I haven't pushed it too hard yet- I probably won't know for sure until tomorrow.
Thank you!
