dc11
| Posted: Tue Sep 02, 2008 1:50 am Post subject: Inverting picture |
I've tried to find a manual for my recently acquired Mitsubishi 1250 CRT projector, but it seems I'm not going to find one. I need to change it from floor to ceiling mount, but I suspect it's going to be fraught without the manual.
Is there any way to do it in software running off a pc?
Cheers
| Posted: Tue Sep 02, 2008 1:58 am Post subject: |
There's a manual on here for the 1281. Did you look at it to see if its similar to yours. Sometimes these changes are the same through newer models. Worth a look.
dc11
| Posted: Tue Sep 02, 2008 3:25 am Post subject: |
Cheers guys. I looked at that but the 1281 looks well different from the 1250. Souns like I can do some serious damage if I muck it up.
outwest
| Posted: Tue Sep 02, 2008 6:15 pm Post subject: |
It was quite some time ago and I don't remember the model number, but another member was looking for a manual for his Mitsubishi projector. Mitsubishi has a separate department for their large monitors and "professional" displays. He was able to get the needed information direct from Mitsubishi. The phone numbers that I have are (888) 307-0309 for Tech and (888) 307-0308 for parts.
These are USA numbers and I see that you are in NZ. I did have an e-mail address for them, but I can't find it at the moment. I will try to find it and post.
outwest
| Posted: Wed Sep 03, 2008 6:06 am Post subject: |
I did find the e-mail contact that I had been using. It is: amaldonado@mdea.com I guess there would be a problem if that individual is no longer working there. Also the 888 toll-free numbers are probably not good for out of country calls. I did find a regular number. It is: (949) 465-6419
dc11
| Posted: Wed Sep 03, 2008 6:45 am Post subject: |
| outwest wrote: | | I did find the e-mail contact that I had been using. It is: amaldonado@mdea.com I guess there would be a problem if that individual is no longer working there. Also the 888 toll-free numbers are probably not good for out of country calls. I did find a regular number. It is: (949) 465-6419 |
Wow, thanks for that! I'll look into it.
Cheers
David
