Warranty coverage and process on the EXT +HD ? Picture shake
Elaine Benes
Posted: Sun Aug 31, 2008 5:58 am    Post subject: Warranty coverage and process on the EXT +HD ? Picture shake
I have a PJI EXT+HD which has a "shake" to it. My $100. HD Fury Gamer Edition produces a rock solid image, but the more expensive Moome has a shake with all sources which won't go away.
How do I get this fixed/replaced ? Is there a warranty coverage ?
Posted: Sun Aug 31, 2008 2:49 pm    Post subject:
Contact Moome at moome@curtpalme.com
Elaine Benes
Posted: Sun Aug 31, 2008 4:52 pm    Post subject:
Has anyone else experienced this picture shaking with the Moome EXT-HD ??
This is disappointing considering the cost and reviews of this product. I expected it to be much better than the far less expensive HD Fury Gamer Edition, but with this issue, it can't even compete...
Elaine Benes
Posted: Thu Sep 04, 2008 2:42 am    Post subject:
Your address for Moome won't accept anything from a Yahoo address, you have to use his direct address...
WTS
Posted: Thu Sep 04, 2008 1:12 pm    Post subject:
I've had a few of the ext hd versions and have never had a problem like that.
Walter
Elaine Benes
Posted: Thu Sep 04, 2008 1:49 pm    Post subject:
You're lucky, its a very annoying problem, and it doesn't look like its going to be addressed by the maker, I've gotten two, very brief, non-committal emails from Moome and he pointedly did NOT provide an address for warranty repair. This problem makes my supposedly more valuable piece of equipment worthless. I couldn't in good conscience sell a piece of equipment that wasn't working properly.
ralpharch
Posted: Thu Sep 04, 2008 4:14 pm    Post subject:
I emailed Moome about my intermittant power connection problem, and in my case I got a very short email answer back saying yes send it back for repair. I have the address on the original box I had - but I wasn't sure whether to send it back to Moome or Barry.
In any event I didn't feel appropriate/worthwhile to send it back all the way to Taiwan for a power connection problem so took the box apart and resoldered the three connection pins on the board like three times. This didn't fix anything. It turns out my problem is in the HP power pin, not the jack on the board. I get a solid power connection using another 9 vdc supply, unfortunately that is only rated at 350 mA and the box says to use a 1 A supply. I suppose I will just buy a connector locally and cut then end off the 2 A HP supply and hope I get the polarity right on the splice.
Edit - I did end up shipping it back to Moome after all when it got pretty bad staying off and my 350 mA wouldn't work either. But its expensive to Taiwan- Fed Ex wanted $120 minimum so I went USPS and that was $40.
Elaine Benes
Posted: Thu Sep 04, 2008 4:17 pm    Post subject:
I'd actually be happy to get an email saying "send it back for warranty repair" because as of now, this box is worthless.
Rolls-Royce
Posted: Fri Sep 05, 2008 10:07 pm    Post subject:
Nope. And mine was one of the first batch that needed the other fixes. Moome sent me the parts at my request, and I installed them. No issues since then.
....Royce....
Elaine Benes
Posted: Fri Sep 05, 2008 10:12 pm    Post subject:
Further testing has shown the Moome does not like my Monoprice HDMI switcher. The shaking only occurs when the switch is in the chain, when I remove the switch, the shaking is gone. My mistake.
However, now I have to decide between keeping the Moome which will not work properly with the switch which allows me to have my HD-A1 attached to it, or keep the Moome and buy another switch hoping it will work with the HD-A1 which has proven to be awfully picky about its HDMI connection status...
moome
Posted: Thu Sep 25, 2008 7:57 am    Post subject:
a Switcher will be cost under $100~
WTS
Posted: Thu Sep 25, 2008 11:05 pm    Post subject:
I tryed a Monoprice 4x1 HDMI 1.3 switch and it wouldn't work with the full HD on 1080p, then I tryed an Oppo HDMI switch and it worked perfect on 1080p. So the problem was the Monoprice and not the Moome HDMI unit. Now I'm stuck with a Monoprice unit because by the time I pay to ship it back and get a refund it will cost me half of what it cost. Monoprice crap!
Walter
Bucketfoot
Posted: Thu Sep 25, 2008 11:33 pm    Post subject:
I'm using the Oppo HDMI switch with no issues as well.
moome
Posted: Fri Sep 26, 2008 3:12 am    Post subject:
oh, WTS, i am very interesting to test your Monoprice 4x1 HDMI 1.3 switch , can you send me?
WTS
Posted: Fri Sep 26, 2008 3:15 pm    Post subject:
Hi Moome,
I wouldn't bother using this one, like I said it doesn't work on 1080p. I would say I just got a bad one as I have heard some say they worked okay for them.
Walter
moome
Posted: Sat Sep 27, 2008 3:20 pm    Post subject:
oh, no problem, if you send me, I may replace a new chip for you~
WTS
Posted: Wed Jan 28, 2009 7:42 pm    Post subject:
Hi Moome,
Did you still want me to send you the Monoprice HDMI switcher?
Walter
Walter
