HDMI PORT
ac/dc
Posted: Fri Aug 29, 2008 1:09 am    Post subject: HDMI PORT
I just had a new Dish networks HD satellite system installed. I have a Sony 1272 receiver
The back of the satellite box has a HDMI port. What is that for? What does it do?
I can't see how I could hook it up to my 1272.
MikeEby
Posted: Fri Aug 29, 2008 2:37 am    Post subject:
The only way to get HD out of the newer Dish Network receivers is either component or HDMI connections. I don’t think the 1272 has a component input but there are several options.
X-Vue Box1040 "Lite": Component to RGB Converter for $149 that will take the component output of the Dish receiver and convert it to RGBHV that your 1272 will accept. It also has a gamma boost adjustment that will improve your shadow detail.
http://www.curtpalme.com/Box1040.shtm
RTC2200: Component to RGB Converter with Gamma Boost $189 very similar the Box1040
http://www.curtpalme.com/RTC2200.shtm
If you want to run a digital signal (HDMI) to the 1272 here are some other options.
HDFury: Universal DVI/HDMI (HDCP) to RGB Converter $99 or $149 if you need the power supply, but no gamma boost.
http://www.curtpalme.com/HDFury.shtm
HDfury2: Universal HDMI to RGB Converter $249 state of the art converter but not available until next month.
http://www.curtpalme.com/HDfury2.shtm
EXT-FULLHD: Universal HDMI 1.3 to RGB Converter $335 most full feature converter including gamma but a little costly.
http://www.curtpalme.com/EXT-FULLHD.shtm
BTW I have a new Dishnetwork 211 and it looks pretty darn good via component.
