mike calcott
| Posted: Fri Aug 08, 2008 7:19 am Post subject: G70 Shuts down |
I have just fitted replacement blue and green tubes in my G70, I now notice that after running for about 15minutes it shuts down with error code 30, after leaving it about an hour it will start up again only to shut down again after another 15 minutes. I was running Ok before the tube change, any ideas?
I seem to have now fixed the problem, I have re-seated the DC board, I must have dislodged it when changing tubes.
I still have another problem if anyone can advise, the brightness control seems to have no effect so I cannot adjust my black levels, this was the case before changing tubes but I assumed that was because the old tubes were being driven hard. If anyone can advise I would appreciate.
Thanks Mike
_________________ Old dog learning new tricks
