erick0071
| Posted: Sat Aug 02, 2008 4:24 am Post subject: ?'s on how to calibrate my HCL4715W RPTV |
First of all, thank you for this great forum. I am about to order the i1 and will be using ColorHCFR to do my initial calibration. But I have some questions that i would like to ask?
I have ventured into the SM on my Samsung HCL4715W before and did minor adjustment...mostly to my geometry...but i have done some in the picture department too..like disabling the SVM and minor adjustments to the cuts and drives since they had too much red. The only odd thing is that my TV would have a horrific contrast and brightness unless i select the custome mode on the user menu and lower them both. But i tried to make them more safe by lowering them on the SM too, but even the lowest settings on SBT (Sub-BRT) and CON (Sub-CONT) on the SM would have a significant effect on the overall picture. I just like to know if there are any other features on the SM that help lower contrast and brightness during my calibration instead of using the user menu because it would be really tedious to be changing between the SM and normal tv viewing during calibration. I would also like to know the function of some of the other items on my Picture MENU on the Service Menu. Here they go:
RDR: R-Drive, GDR: G-Drive, BDR: B-Drive, RCT: R-Cutoff, GCT: G-Cutoff, BCT: B-Cutoff. All of these for grayscale cal. right?
SBT: Sub-BRT to increase or decrease brightness right? even thoug the lowest setting it's still to high.
CON: Sub-CONT to increase or decrease contrast . Also did not help much even on the 0 setting.
COL: Sub-Color to adjust overall color or saturation ?
HUE: Tint to adjust hue?
RYR: R-Y Axis ... \
RYB: R-Y Axis |
NO IDEA WHAT THESE ITEMS DO
GYR: R-Y Axis |
GYB: R-Y Axis /
GAM: Gamma i believe
SHP: Sub-Sharp sharpness i assume
SFO: SHP-FO no idea
POV: Pre-Over no idea
LTI: Luminance...i would like to know more about this
VML: VM-LBL disables SVM right?
VMD: VM-Phase no idea
DCT: DC-Tran no idea
DPI: D-PIC no idea
HPF: HPF/BCOF no idea
VPF: VPF/HCOF no idea
VPG: VAPGAIN no idea
VPI: VAPINV no idea
RCO no idea
GCO no idea
BCO no idea
BPO no idea
BWD no idea
Please any help will be appreciated ..only if you only know some of them and not all. It will help me greatly before venturing into my calibration to know what some of these other item affect.
Erick
