PortlandGTS
| Posted: Fri Jul 25, 2008 3:18 am Post subject: RS-422 switch for NEC XG852 |
Hello,
I need to switch the communications port on my NEC XG852 from RS-232 to RS-422 (to interface with an Extron LDxi). I found the following instructions (poor English and all) in an NEC manual:
"When you change serial communications system RS-232 and RS-422, the projector requires to change setting of switch (S8121) on SYSTEM PWB."
I took the cover off the projector, but can't find switch S8121. I'm not even sure which circuit board they refer to. Can anyone give me a pointer to where to look? And am I looking for a DIP switch, a jumper, or something else?
Tom
_________________ PortlandGTS
jarseneau
| Posted: Fri Jul 25, 2008 5:30 am Post subject: |
The SYSTEM PWB is at the back of the cardcage with the small cables going to the rear LEDs for standby, etc. The switch will have the number near it. I believe it is in the center of the board.
_________________ Jerry
PortlandGTS
| Posted: Fri Jul 25, 2008 9:57 pm Post subject: |
Jerry,
Found it. Thanks.
Tom
