Help me understand Lumagen's memory system.
energeezer
Posted: Mon Jul 07, 2008 2:08 pm    Post subject: Help me understand Lumagen's memory system.
Perhaps someone here can help me understand the Lumagen memory system.
I have selected Independent memories and am able to store memories for my currently used inputs. I have two separate configs for Input 1. One which outputs 1080i/72 for 1080i/60 input and one which outputs 960/60 when it senses a 480i input.
I have two separate configs for input 2. One which outputs 1080i/72 for 1080i/60 input and one which outputs 817/60 when it senses a 1080/24 input.
This all works fine and is all linked to memA on both Input 1 and 2.
What I don’t understand is how to properly use the memA, MemB, MemC, MemD memories. By reading the instructions it looks like if I select input 1 then press memA and then calibrate and save this should stay in MemA. This seems to work but when I do the same for MemB it overwrites what I had done on MemA. Now MemA and MemB are the same.
Can someone give me some guidance on the proper way to use Mem A,B,C,D? I have read the manual over and can’t seem to make it work.
Steve
Posted: Mon Jul 07, 2008 2:15 pm    Post subject:
When you hit save I think it gives you a few choices, I'm at work now but I think it asks save for all memories, or you can move the arrow key either left or right i think to change it to just memory A,B,C,or D. Like I said I'm not sure but I think it works this way, its been over 6 months since i changed anything.
