parametric low-level gamma adjustment for htpcs
Posted: Mon Jun 23, 2008 10:40 pm    Post subject: parametric low-level gamma adjustment for htpcs
Now your piracy box can have highly detailed per-channel gamma implemented at the 10-bit DAC level instead of post-processing on already 8-bit-per-channel rendered frames. AWESOME!
http://www.avsforum.com/avs-vb/showthread.php?t=1042214
FFDshow doesn't really have an equivalent and even then would only post-process the 8bit framebuffer data, so you'd get sub-8-bit quality and potential banding. Yaay!
Jesse S
Posted: Wed Jun 25, 2008 12:56 am    Post subject:
Ffdshow has Levels and within that a curve. But it doesn't allow manipulation of each color.
This could be added. I don't know if it would achieve the same result or if it's as good a point to manipulate the gamma curve.
