Can the faroudja 5000 do 72 Hz refresh rate?
jaredjaric
Posted: Mon Jun 23, 2008 7:42 pm    Post subject: Can the faroudja 5000 do 72 Hz refresh rate?
THe set up is:
PS3 at 1080p24 fps - hdfury - Faroudja 50001080p 72fps? - CRT
schmoe
Posted: Mon Feb 09, 2009 12:30 am    Post subject:
Hey Jared, did you ever figure out the answer to this? I'm curious to know as well.
Posted: Tue Feb 10, 2009 6:55 am    Post subject:
Me too Wink
Posted: Tue Feb 10, 2009 7:51 am    Post subject:
the only VP I know that can do 1080p@72 is the TV-one C2-2xxx series of Processors.
SYC
Posted: Tue Feb 10, 2009 8:37 am    Post subject:
Can Farouja do 1080P 48Hz? I was told it can't, but I suspect this.
SYC
schmoe
Posted: Wed Feb 11, 2009 7:40 am    Post subject:
Really? I thought the VP50 and Lumagens support it. Hmm...
Posted: Wed Feb 11, 2009 2:45 pm    Post subject:
No they don't, the lumagen only can do up to 60hz at 1080p, and I think the VP50 can do something less like 1050p@72z and I am not sure of the vertical line number but with reduced timings... that can cause issues with certain PJ's.
But for scope BD movies 800p@ 72 works just fine for both.
Axatax
Posted: Mon Feb 16, 2009 4:42 pm    Post subject:
*All* those processors will support 72Hz (I've owned each one at one time or another).
What they won't do is run 1080p72 through the DVI/HDMI ports - you're limited to RGB output for 1080p72.
Posted: Mon Feb 16, 2009 5:31 pm    Post subject:
I should have clarified through the Digital outs it wont do 1080p@72, where as the Tv-one C2-2000A series will.
