1271 shaking vertical lines
tony359
Posted: Sun Jun 22, 2008 3:46 pm    Post subject: 1271 shaking vertical lines
Here again. I didn't do anything this time Smile
Today I played a bit on PS3 for 30 minutes at 1080i, then switched to HTPC (576p) and suddenly the vertical lines started shaking. Only in the lower and upper part of the screen, not on center.
The shaking was present on the empy input too, on patterns too. Rebooting the HTPC and the CRT didn't solved.
I watched an entire movie, and at the end of it all was perfect.
More than disassemble everything and reassemble averything, any opinion?
Ciao
Antonio
Edit: I forgot. All three colors affected. The shake is not continuous but, say, two every seconds, irregularly. I'll try to take a shot with my cell phone. From my seating point I can just see the red lines that go out of convergence of, say, 1/2 of inch, from a 100" screen. But if I turn on a tube at a time, I can see the shake on all three colors. Seems that the colors are not shaking in the same way.
