Upgrade from a 9PGXtra to a 10PG??
rtart
Posted: Mon Jun 16, 2008 10:40 am    Post subject: Upgrade from a 9PGXtra to a 10PG??
Hi all. I have an opportunity to replace my NEC 9PGXtra with a 10PG. My 9 works great, has great tubes, has a 1996 build date, and has performed flawlessly for seven years. (I bought it from Curt in 1998/1999, and didn't realize for a couple of years what I had.) In other words, I'm only considering the 10Pg for an increase in PQ.
I also have a working 9PGx with bad tubes for parts, so I should be able to use my 9PGx for the foreseeable future. My strategy to this point has been to use the 9PGx until it dies, hoping that the digital performance/price equation would then make sense. It seems every month that digital machines are getting closer to CRT. Because of this, I would probably replace my CRT with a digital machine, if my CRT were to die today. (I know, I'm a traitor.) Saw the Runco DLP with an anamorphic lens advertised for sub-$5k in this month's Home Theater Mag, so the process seems to be moving along.
Anyway, my question is whether spending around $1,500 plus freight for the 10PG is a good idea. The same money can make a dent in the price of a digital PJ, and my 9PGx has a great picture with BD, HDDVD and HDTV sources.
My quandary is whether the increase in PQ will justify the extra bucks.
Opinions and advice are welcome.
__________________
deronmoped
Posted: Thu Jun 19, 2008 3:57 pm    Post subject:
The 10PG would be a big step up, after owning the 10PG you might not even want to switch to a digital. Now most of the parts out of a 9PG will work in a 10PG so you will have spare parts. You already know how to set up a CRT so the 10PG will not be that much of a struggle to set up.
Deron.
rtart
Posted: Thu Jun 19, 2008 4:05 pm    Post subject:
Deron.
Thanks Deron. I'm still in a quandary, but getting closer. Just can't quite go digital after years of CRT. I'm also considering waiting until I find a 9500, Cine9 or a G90 as the prices fall. Not sure how cheap these units are going to get, though, so I'm thinking the 10PG may be my best bet. I just have to fly (using an award ticket) to pick it up, and drive back 12 hours in a rental car to get it home. Then lift it up and set it up.
Tinman
Posted: Thu Jun 19, 2008 11:56 pm    Post subject:
The 10PG is a big step up from any AC projector. It's also pretty straight forward to make a "plus" out of it.
The biggest difference is how the 10PG can suck you into the image. I think it was worth it.
Marc
This space for rent.
Posted: Fri Jun 20, 2008 12:21 am    Post subject:
Marc
Shocked Then how do you get out? Very Happy
rtart
Posted: Fri Jun 20, 2008 1:38 am    Post subject:
Kinda like the old Maxell "Blown Away Guy" commercial, in reverse?
deronmoped
Posted: Fri Jun 20, 2008 4:21 am    Post subject:
These other PJ's are pretty much the same as far as watching video. The only big advantage is the brightness of the G90, the downside is shorter tube life.
Deron.
Elaine Benes
Posted: Fri Jun 20, 2008 10:20 am    Post subject:
You gotta see it running first.
I too used to think ANY 10PG would be a great thing to have, then I saw one that had its ref/mech/white balance ruined so it had virtually no light output. The picture was dim, even at 100 contrast/brightness. Whoever set it up ruined it. Focus was terrible too. I had arranged to trade an XGLC and immediately passed on the deal after seeing how badly that poor 10PG had been set up.
So, as always, buyer beware and let your eyes be the judge.
10PG's *should* be VERY bright, and VERY well focussed, three examples that I've owned were just like that, the one I passed on was NOT at all like that...
Posted: Fri Jun 20, 2008 11:14 am    Post subject:
So why didn't you make a lowball offer an redo the white balance?
grogthegreat
Posted: Fri Jun 20, 2008 8:53 pm    Post subject:
I think he might be referring to the mechanical trim pots inside the pj. I've heard that in order to reset those you need an oscilloscope, a colormeter, and a clear idea of what you're doing.
-Greg
First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
Posted: Fri Jun 20, 2008 10:08 pm    Post subject:
I think you're right.
I also think that it is possible to do this, I've done two Xtras and my XG.
I lastly would think that Elaine (Paul GN2 I think) would be capable of doing it too. Smile
Elaine Benes
Posted: Sat Jun 21, 2008 12:22 am    Post subject:
I've actually "done" two myself, but not nearly good enough for me to have any confidence. The colorimeter I'm not afraid of, but the oscilloscope, that I need a LOT more experience with.
It was a buddy though that had it, and lowballing just wasn't in the cards. I would certainly have purchased it for the right price, but when I saw how poorly it compared to my burned tube XGLC that I was offering in trade(with cash), I just couldn't do the deal.
dbaisey
Posted: Sat Jun 21, 2008 9:12 pm    Post subject:
For the sake of saving 10PGs from being parted out give this a try.......
Register a video freq and use the video input. Feed a NTSC all white test pattern to it (with no position corrections) and set brightness to 50 and contrast to 75. Let it set for a bit. Turn on AKB from the info menu and let it do its thing, this should bring levels up to a nice bright white. Shut off AKB and store it.
Copy AKB to other RGB signal entries. If your changing a system board this may be what you need to do. Doug
If the pots were messed with then dont do this until you can confirm voltages. After signal entry make sure the phase is ok for that freq, it should be bright without streaking.
Tinman
Posted: Sat Jun 21, 2008 10:01 pm    Post subject:
Marc
Let me tell you, it was a looong walk out of Lord of the Rings. Mr. Green
Marc
rtart
Posted: Mon Jun 30, 2008 5:49 pm    Post subject:
Well guys, I did it. My 10PG is now sitting in my basement ready for me to finish up the unistrut mount and hang it. It IS a beast!
This thing really looked great when I was able to see it in action before buying it. Tubes look new, literally. Couldn't find anything wrong with it and it made it up to ATL from Palm Beach, FL in one piece.
I'll keep you posted on my progress.
Thanks to all for their assistance.
Posted: Wed Jul 02, 2008 5:47 pm    Post subject:
Congrats! I am in Atlanta for the next week or so. If you need any help then give me a buzz.
rtart
Posted: Thu Jul 03, 2008 12:25 am    Post subject:
You've got great timing. I just finished hanging it and doing a prelim alignment a moment ago. Sure could of used you an hour ago, but I'm good to go. (Just tired!)
Posted: Thu Jul 03, 2008 1:29 am    Post subject:
That is cool. I would like to check it out sometime.
rtart
Posted: Sat Jul 05, 2008 2:07 pm    Post subject:
For those still interested, I bought the 10PG and it is a great improvement in brightness, detail, and contrast over my 9pgxtra. (Which was no slouch.) I paid $1100 for it, but had to fly (using a free ticket) from ATL to Palm Beach, FL and drive it back. 10 hours in a mini van, and a day and a half hanging and setting it up. Well worth the trouble and expense.
Others who are on the fence about upgrading to a 9" machine, or going digital may want to know my vote is for CRT. I have a machine that is like new with a picture head and shoulders above any digital I've seen for less than $15,000. Basically, I paid about the same price as a new bulb for a digital PJ, and the performance and longevity is an order of magnitude better.
Of course, you all already knew that.....
Posted: Sat Jul 05, 2008 2:37 pm    Post subject:
Now there's dedication to the hobby Thumbs Up See you in a few week's after you watch a few dozen movies. Very Happy
