Moome upcoming External HDMI1.3->RGBHV or Internal Marque
audvid
Posted: Fri Jun 06, 2008 2:21 pm    Post subject: Moome upcoming External HDMI1.3->RGBHV or Internal Marque
I had ordered the upcoming moome external 1.3 box but found that it has been delayed till end of june.
Should I wait for that box or should I just buy the internal marquee card (which is presently in stock)
In terms of picture quality, would the upcoming box be better?
Thanks.
Posted: Fri Jun 06, 2008 2:51 pm    Post subject:
No Internal is always better from what others have reported. Get The internal much easier to use.
jpdawg76
Posted: Fri Jun 06, 2008 3:43 pm    Post subject:
Are there any functional differences between the two? Picture quality? Color reproduction?
Posted: Fri Jun 06, 2008 3:48 pm    Post subject:
Well the internal is only one input for hdmi where the box has more. picture wise most say the internal is better I only have the internal so I personaly cant tell you, just from what others have said here and on AVS. if you want more inputs and are not using a scaler for switching or a reciever wait for the external. But like I said the internal should have a slight improvement for picture quality.
jpdawg76
Posted: Fri Jun 06, 2008 3:56 pm    Post subject:
I'm in the same boat as audvid. I have a VisionHDP arriving on Monday to feed my Marquee 9000LC. I also pre-ordered the external HDMI->RGB Moome box but am considering ordering one of the VIM-HD cards instead.
Bruce 09
Posted: Fri Jun 06, 2008 4:03 pm    Post subject:
IT would be nice to hear from moome on this but I this new external box should have lot of improvements over the previous external boxes. The main differences is newer improved components and design for the 1.3 SPECS . I would think the externals performance difference to the internal would be very close now .
Bruce
Posted: Fri Jun 06, 2008 4:19 pm    Post subject:
I'd cancel the order since your getting the lumagen and switch it to the HD-VIM.
audvid
Posted: Fri Jun 06, 2008 5:53 pm    Post subject:
How does moome internal card compare with hd fury. I understand Moome products are great but do they have occasional glitches because they are hand assembled and small run etc..? I just don't want to have to mess around with fixes or upgrades after getting the product. I am not a tweaker. I just want to go with a proven product. Currently I am using a Dtronics dvi to vga box. I am concerned that it might not be a true 1080p capable unit but I don't know. I tried HD fury once before but not with 1080p - only with 1080i and it was not any better or worse than my current Dtronics. Hence, I sold it. It was a while ago. I read elsewhere that that HD fury is a very good product too.
Has anyone compared moome internal card with a HDfury? I might go with a lumagen processor and I don't need the gamma correction offered by moome.
suggestions please?
Thank you.
Posted: Fri Jun 06, 2008 5:59 pm    Post subject:
Athanasios,
You're confusing the old EXT-HD external box with the new EXT-FULLHD external box that the original poster is asking about. The new EXT-FULLHD only has 1 HDMI input (but it's HDMI 1.3) while the old EXT-HD had a couple of HDMI 1.2 inputs and a component input.
The VIM-HD has one HDMI 1.2 input and one component input.
The items new to the EXT-FULLHD are listed in bold on the EXT-FULLHD order page and in the EXT-FULLHD FAQ:
EXT-FULLHD Specifications
  • INPUT: HDMI 1.3 (100% digital)
  • OUTPUT: RGBHV (VGA)
  • Deep Color mode support (10bit and 12bit)
  • HDMI 1.0, 1.1, 1.2, 1.3, HDCP 1.1, and DVI 1.0 compliant
  • DTV mode support (480P,576P,720P,1080i,1080P) for 50 and 60Hz
  • PC mode support VGA, SVGA, XGA, SXGA, UXGA, etc
  • Supports 640x480 up to 1600x1200 (PC), and 480p up to 1080p at 72Hz (Video)
  • Any resolution and refresh rate up to 225Mhz pixel clock is supported including 1080p/72Hz
  • Supports 4:4:4 RGB / YCbCr input
  • Supports 4:2:2 YCbCr input
  • Support both 16-235 and 0-255 color range and auto selects correct value
  • BT601 (component) and BT709 (HDTV) colour space transform support with auto mode detect for correct colour space
  • 14bit Data processing with high precision 200MHz 10bit DAC
  • Adjustable gamma boost for perfect shadow details and gamma tracking
  • Adjustable white level boost for output from 0.7V-1.0V for perfectly matching a display's expected input voltage
  • High speed 1GHz output
  • RGBHV output driver stage, allowing the use of long output cables without problems
  • Supports 120Hz for 720P and 1080i
  • PC plug and play
  • Metal box for cleanest electrical environment & high definition content processing
  • Global power supply (100V-240V)
  • Toslink (fibre optic) digital sound output of compressed 7.1 or uncompressed 2 channel PCM
  • Supports both RGBHV and RGBS output (user adjustable)
  • Adjustable sync polarity for both H and V lines (positive/negative)
Items listed in bold are new features since the previous EXT-HD box.
Whether the internal VIM-HD will provide a better image quality than the EXT-FULLHD is anyone's guess as nobody has both. The EXT-FULLHD isn't even out yet! The EXT-FULLHD does have some nice enhancements but then the VIM-HD is directly integrated with the Marquee.
