ROFLmaker
| Posted: Thu Jun 05, 2008 3:39 pm Post subject: HDMI TO RGB or VGA?? |
Ok I essentially have a 42" old Sony "Monitor" (2 comp inputs(labled RGB/YUV), 2 audio headphone input, a 3.5mm adio output , an S-video, and a cable input). its HD. I have been told that i should get a HDMI to VGA converter (external) where it splits to VGA and then has a jck for audio. and then I have been told I should just go from HDMI to DVI to VGA and I have also been told I should go from HDMI to RGB... What hould i do in term of picture and the also how do i get the sound to go from the back of theDish HD box to the TV which only has audio inputs like headphones?
CRT_Ben
Joined: 28 Aug 2006 Posts: 1684 Location: Northern Virginia
| Posted: Thu Jun 05, 2008 6:03 pm Post subject: |
RGB and VGA are interchangeable. As for the audio, get yourself a stereo RCA cable and a 1/8" stereo male to 2xfemale RCA adapter/cable and you'll be all set.
kal Forum Administrator
| Posted: Thu Jun 05, 2008 7:36 pm Post subject: |
Sorry, but what exactly are you trying to do? Connect HDMI devices to this display? IF that's the case Moome's EXT-FULLHD will work fine - it'll convert HDMI to RGB ( same as VGA). As long as your display has a VGA / RGB input it'll work.
While the EXT-FULLHD can split out the audio from the HDMI signal too, you'll need an optical input on your display to use that (which I don't think you mentioned you have), so best to just use regular analog RCA audio cables (stereo) to feed the display. Or better yet, feed the audio separately via Toslink to a receiver or something.
ROFLmaker
| Posted: Thu Jun 05, 2008 11:11 pm Post subject: |
What about loosing the digital to analog? will the moome maintain the Digital Signal or will it be converter to analog?
