Need help getting 1080i on ATI hd 2400 card
dave1234
Posted: Fri May 30, 2008 6:36 pm    Post subject: Need help getting 1080i on ATI hd 2400 card
I've just upgraded my onboard graphice to an Ati HD 2400 pci card, for hd dvd playback. I want to use 1080i as my resolution, and in the catalyst control panel there is an option to make this resolution available. I check it off, and I still can't find that rez in the available resoultions. I can't find a manual for this card, does anyone have any ideas?
Elaine Benes
Posted: Sat May 31, 2008 1:07 am    Post subject:
You likely have to UNCHECK the box about using the EDID information, or whatever the terminology is that says for it to restrict the resolutions to ONLY those that your display says it can handle. There's a box in the control panel for this...
dave1234
Posted: Sat May 31, 2008 2:04 am    Post subject:
Ok, I found the box, and unchecked it. I still don't see 1980x1080i @30, I do see 1980x1080 @30. Is this 1080i or 1080p?
Thanx for the help.
Elaine Benes
Posted: Sat May 31, 2008 2:10 am    Post subject:
If its at 30, its 1080i...1080p would be at 60...
Elaine Benes
Posted: Sat May 31, 2008 2:12 am    Post subject:
However, being a computer, they might be doing 1080p at 30Hz refresh instead of "real" 1080i at 60Hz refresh..if that makes any sense ?
Electronically, 1920x1080 30Hz will look like 1920x1080i at 60Hz...
