Barco 1208 Blocks
tri_joel
Posted: Sat May 24, 2008 1:01 am    Post subject: Barco 1208 Blocks
The manual doesn't make much sense to my simple brain.
I would like to have two different blocks on Port 3 so I can watch FiOs HD channels and SD channels. Is it possible? I see how to delete blocks and how to copy blocks, but I don't see how to create blocks. Does it switch automaticly like my old PG9+?
Peace,
Joel
Ile
Posted: Sat May 24, 2008 9:12 am    Post subject:
Just chance resolution from source and projector creates new block.
Copy block can be used to copy adjustments from another block. Only useful thing is that it copy also color adjustments.
Gerbrand
Posted: Sat May 24, 2008 11:40 am    Post subject:
Also: if you press 9+source number (eg. 93), you get a second set of blocks that can have the same frequencies as the original blocks (the Barco identifies which block to use by looking at the H&V frequency combination.
Gerbrand
BG1209s (color filtered,new LUGs!), 13000h
Bat cave
tri_joel
Posted: Sat May 24, 2008 11:44 am    Post subject:
Thank you Gerbrand.
Just to make sure I understand, the Barco creates a new block when I change sources, I then do a new convergence and when I switch back to the other source the Barco automaticly changes back to the previous block that matches it.
Peace,
Joel
www.vawinesnob.com
r.bauer
Posted: Sat May 24, 2008 2:10 pm    Post subject:
The barco creates a new memoryblock when you change one of these: table/ceiling or front/rear orientation, V-freq, H-freq or input. It stores the memoryblock only if you change a parameter in the menu, or else all blocks would be filled up in no-time after a little experimenting with resolutions/sources.
An additional memory block can be applied to the same combination of table/ceiling or front/rear orientation, V-freq, H-freq or input setting by selecting 9+ original input (9-1, 9-2, 9-3, 9-4, 9-5 etc)
Posted: Sat May 24, 2008 4:35 pm    Post subject:
It might be helpful if you read the Barco FAQ. You can find it here...
http://www.avforums.com/forums/forumdisplay.php?f=72
tri_joel
Posted: Sun May 25, 2008 2:43 pm    Post subject:
Thank you everyone, it's starting to make sense to me now.
Peace,
Joel
www.vawinesnob.com
