97ss150
| Posted: Fri May 23, 2008 2:51 pm Post subject: RED RING OF DEATH |
i HATE microsoft!!!! i know curt can fix it and if i had the 100 bucks he would be fixing it. i got laid off from work a few weeks ago and just dont have the spare cash laying around. but the funny thing is, the rep at microsoft tried to tell me that my warranty ran out in march, since it was only a one year warranty. and i said "see thats the thing, this is such a problem that you guys had to extend the warranty on these things to 3 years because its so bad. Therefor my warranty is good until next march" so in your face microsoft lol. anyways now i get to play the wait game
RANT OVER
henry
| Posted: Fri May 23, 2008 2:55 pm Post subject: |
So did the idiot admit there's a 3 year warranty on the unit, and are you sending it in?
97ss150
| Posted: Fri May 23, 2008 2:58 pm Post subject: |
yes on both accounts. but they damned sure werent going to release that information if you didnt already know about it
97ss150
im really tempted to fix it myself
JustGreg
| Posted: Fri May 23, 2008 3:01 pm Post subject: |
Yeah I'm curious if Rasheed finally asked a supervisor too. As long as you didn't break the security seal, it still has a couple years left on the warranty.
Mine has already been in once for replacement. They just send another one back. Now it's starting to lag and lock up when hot. Sooooooooo....I get to talk to India again. YAY! (I love F-ing with those guys!) This time I'm going to pitch a bigger fit and try for an Elite. I think under the consumer protection laws of my state however I may have to go through the replacement process one more time before that may work....I'll have to check into it.
I wish you luck finding another job Henry.
EDIT:Oh. I see you replied while I was replying. I wouldn't try to fix it yourself. I'm not saying you're not capable, but 'fixing it' isn't a for sure 100% every time procedure. Worst case scenario, you're REALLY screwed if it doesn't work.
_________________ Greg
97ss150
| Posted: Fri May 23, 2008 3:11 pm Post subject: |
ya the job i just got laid off from was an electronics tech. specializing in circuit boards
It appears that multiple failures are common on the old boxes. I am about to post a solution for people that use me for services, so they can re-repair the boxes themselves. I've made it so that as long as you have a Torx driver, you can reseat the chips and heatsinks yourself.
I know a lot of repair guys have dropped out of the market, as short of machining a new larger heatsink, re-repairs are going to be required. Seems a bunch of MS repaired boxes are going down as well. The newer boxes have larger heatsinks, but once the RROD happens once, it will keep reoccuring, as the separation of the main chips and board has already occurred. Iv'e done maybe 30 boxes now, have had at least 1/2 of them come back. I'm still doing them, but with the above disclaimer up front. At least I'll have the article on the site showing how you can redo the repair yourself.
97ss150
| Posted: Fri May 23, 2008 3:41 pm Post subject: |
im going to wind up ditching this thing and getting a ps3
JustGreg
| Posted: Fri May 23, 2008 3:42 pm Post subject: |
There are mods that can be done to the ducting too. Nothing more than plastic rectangles inserted to divert more air to the processor as opposed to the GPU but temp verification proved it worked. Then there's fan replacement and modifications.....Shouldn't have to go through all that sh*t to make something perform it's base advertised function tho IMO.
From what I've been able to gather, the final step after the repair mod for RROD is to unplug the DVD drive and the fans and turn it on for about 2-2.5 minutes until it overheats and the solder reflows. Then there's the scary towel over the heat sink thing to accomplish the same.
I already purchased a couple repair kits on fleabay to fix an RROD console I 'won' but the thing showed looking NOTHING like it did in the pix. It looked like it had been run over so I sent it back and got a refund. That leaves me with the repair kits for the day the extended warranty expires on mine.
I'll see if I can't find the YouTube vid again Curt. I'm sure you don't need it but it may prove entertaining anyway.
| Posted: Fri May 23, 2008 4:23 pm Post subject: |
Thanks, I do fan mods and redirecting of the airflow. I haven't measured chop temperature, but the exhaust air is cold. I put the fans on full speed, but eventually the chips come loose again. I even built a controller that randomly pushes buttons to simulate game play, but even that doesn't cause the units to fail any earlier than with real game play.
Brian Hampton
| Posted: Fri May 23, 2008 5:26 pm Post subject: |
Quote "I'm going to wind up ditching this thing and getting a ps3"
Sounds like a good plan. PS3 is a nice device.
-Brian
| Posted: Sun May 25, 2008 1:35 pm Post subject: |
A friend of mine is already on his forth unit so far. He bought it from Costco and the replacement plan is working for him--too bad the Xbox isn't.
Joust
TV/Projector: Marquee 8501LC
| Posted: Sun May 25, 2008 1:53 pm Post subject: |
| 97ss150 wrote: | | im really tempted to fix it myself |
the real fix it to remove teh video chip, clean off all the old RHOS solder and reball the BGA.
then you must clean off the board and re attach the chip.
can you do this???
| Posted: Sun May 25, 2008 2:19 pm Post subject: |
I dont have one of these but if its a heat problem for the cpu I know there is a cooling chip you could add on top of the heat sink or directlly to the chip. one side gets Ice cold the other side gets hot. So you would put the cold side to the chip needing cooling ans maybe add the heat sink to the hot side along with maybe an exhaust duct if its needed. I do not remeber the name of the chip, i saw it in a ebay sellers store where I got some of my parts. They are used in cars for heated/cooling cup holders and run on 12 volt supply.
Joust
| Posted: Sun May 25, 2008 2:52 pm Post subject: |
Thats a Peltier Diode.
but the problem is the video accelerator chip. there is no place to mount the device because its stuck under the DVD drive. if you have your xbox360 open "before" the failure at a preventive measure. simply putting the duct partition and mod the fan to be on all the time will probably be sufficient.
If your warrantee has expired, i highly recommend this preventive measure.
97ss150
| Posted: Sun May 25, 2008 4:31 pm Post subject: |
| Joust wrote: | | 97ss150 wrote: | | im really tempted to fix it myself |
can you do this??? |
ya we did surface mount, lead free solder, all that fun stuff. not too big a deal, but i really dont want to. only reason i ever even considered it is the timeframe issue but its not like i need the 360, just pisses me off is all
Joust
| Posted: Sun May 25, 2008 4:37 pm Post subject: |
are you sure you did Ball Grid Array? this is a LARGE one. you'll need a temp controlled oven to ramp up the heat in a very controlled fashion.
97ss150
| Posted: Sun May 25, 2008 4:40 pm Post subject: |
i know for a fact i didnt but the guys at the shop have. i didnt do that crazy stuff.
| Posted: Wed Jun 04, 2008 5:18 am Post subject: |
OOOPS I thought by the thread title this was about Hot Wing's the morning after.
akajester
| Posted: Thu Jun 04, 2009 12:11 pm Post subject: |
I know this is an old thread, but after countless attempts to repair my old 360, xclamp mod, fan mod, etc...
This heatgun method finally fixed it!
http://ioverflow.net/xbox360/heatgun1/
I've played it about 5 nights now for over 2 hours each time. I also did a 12v fan mod on the gpu fan and the 360 sounds like a jet engine but when I feel the back it's way cooler.
-akajester
