Pulsing Squiggly Noise? on vertical lines on Marquee(solved)
Posted: Wed May 21, 2008 11:55 pm    Post subject: Pulsing Squiggly Noise? on vertical lines on Marquee(solved)
I have noticed a squiggly pulsing , lets call it noise, going up vertical in my image. Mostly noticeable in vertical lines.
Almost like a power supply noise. something like this ~~~~but going vertical up lines like the grid pattern from a test DVD and pulsing on and off. its not present on internal grid.
Could it be a ground loop problem?
I'm running 1080p48.
Person99
Posted: Thu May 22, 2008 12:55 am    Post subject:
Is it a "hum bar" that rolls up the image in one "bar" or is it all over the image?
Posted: Thu May 22, 2008 1:04 am    Post subject:
Its on vertical lines, remeber seeing this before over On AVS and did a search for squiggly lines and could not find it , so i looked through all my posts Shocked Man I have a lot ! And I found a post by TEOnaki:Marquee 9500LC - "strange waves" - need help.
It was bad solder joints on his clm. The Video links he gave are gone now but I remember how they looked.
I need to go check everything on the Solder joints for the DPB and SWB boards.
Hopefully this is it, Probably from pulling it out and removing the DPB from the main board doing my mods
i maye have weakend the Joints. So this will be added to my Maintenance thread.
Posted: Thu May 22, 2008 1:56 am    Post subject:
Well I think I got it, pressed down on all chips U35 and U16 were very loose and actually "snapped" a bit as i pressed down
Thought i might have cracked the board!!! But it was just the chips being seated. Put Board back in and squigglies and
pulsing are gone for the most part, think I need to pull all chips clean with DeOxit, then some denatured alcohol for final
rinse. that should do it !
rickycleung
Posted: Thu May 22, 2008 4:36 am    Post subject:
I think I encountered that squiggly pulsing internal grid lines on my XG135 before but it is less serious. The video links are right there so I reconigzed what it looks like.
Where to look for those Ic to clean and reseat them in XG135? Thanks.
Ricky
Posted: Thu May 22, 2008 7:06 am    Post subject:
PM MarkAW with this question rickey, he may be able to answer that.
rickycleung
Posted: Thu May 22, 2008 8:17 am    Post subject:
Thanks AnalogRocks. Already send PM to Mark for help.
PaulB
Posted: Thu May 22, 2008 8:45 am    Post subject:
Hey, thats the exact same solution to a problem I had a couple of days ago - you're just copying me now, c'mon, admit it.
Get back to modding and leave me alone, I've been punished enough !!
Laughing
Paul
Posted: Thu May 22, 2008 10:14 am    Post subject:
I don't think it quite works the same way with XGs.
However I would reseat all the boards and all the connections to the deflection board and C-drive, just because.
After that I would suspect the Oscillator board. My XG had a bad Oscillator board when I got it, and that was one of the symptoms, a horizontal jitter (which will make a vertical line squiggly).
There is one chip in a socket on the Osc board, the EEPROM. You could try reseating that I guess...
All other chips are soldered.
It's not like a Marquee.
rickycleung
Posted: Fri May 23, 2008 2:37 am    Post subject:
Thanks Mark. I shall check the boards tonight. I know where to find the deflection board and Osc board but where is the C-drive? I had once pulled out all the boards in the card cage and cleaned the contact with a rubber. Any suggestion on contact cleaner?
The squiggly grid lines is not happened all the times and it is not as serious as shown in the video links. After a while, it gone and will happen again later. Confused
I remember this issue is only affected the internal grid lines. The grid lines pattern of an external sources or picture will not be affected. Confused
Ricky
Posted: Fri May 23, 2008 3:15 am    Post subject:
http://www.curtpalme.com/NECXG_Layout1.shtm
Posted: Fri May 23, 2008 4:06 am    Post subject:
Ricky
Well....no I'll leave that un-said Laughing
rickycleung
Posted: Fri May 23, 2008 4:41 am    Post subject:
Sorry, I don't find the C-drive in the NECXG layout page. Would you point it out?
Oh, my poor english. I used a pencil eraser to clean the contact. Is it no good? Any suggestion on those cleaner?
Posted: Fri May 23, 2008 5:53 am    Post subject:
Your english is fine. A pencile eraser sometime's has oils in it that get left behind after you use it. There's a chemical cleaner called DeOxit, used to clean contact's. It's what everyone uses. Just make sure not to spill it on thing's when you are using it.
Posted: Fri May 23, 2008 6:29 am    Post subject:
It's called a rubber here too.
Rubber has at least three meanings here Wink
rickycleung
Posted: Fri May 23, 2008 7:33 am    Post subject:
Oh well...I see Razz It seems that its abbreviation is same here. The pronunciation of rubber in chinese/cantonese has the same meaning I guess. Mr. Green
Mark, where is the c-drive, please ?
larryk
Posted: Fri May 23, 2008 2:14 pm    Post subject:
I have used Electrosolve contact cleaner with a bristle brush, air to dry off, then treat with Stabilant 22. Stabilant enhances electrical contact and is not a cleaner. I would highly recommend using it on your entire PJ except for the high voltage contacts. It is often used on critical aviation components and medical equipment.
Posted: Sat May 24, 2008 5:03 am    Post subject:
Squiggly is back , It went away for a bit after pushing down on chips, So it came back and I decided to reflow all the solder joits on the DPB conectors male and female. went away for about 15 minutes now its back again, pulsing about every 3-4 seconds for a second then stops 3-4 seconds and starts for a second. Its late now but I will have to clean all chip contacts and try it again, maybe reflow all connector pins too.
rickycleung
Posted: Sat May 24, 2008 5:30 am    Post subject:
This problem is same as My XG135. It went away and back again later. It is not happened for every time the XG is switched on.
Thanks Larry. I shall check any Stabilant 22 is avaliable here.
Posted: Fri Jun 06, 2008 4:05 am    Post subject:
Well I cleaned the board all the chips with denatured alcohol and its still there. 7 seconds no squiggly, then 3 seconds of squiggly. repeates over and over. any other Ideas?
